vMix Call
Missing functions in vMix call.
Has anybody found a good solution on how to remove or cover-up the frozen frame once a person hangs up from the broadcast.
I have an international meeting with 8 vMix calls coming up that we are broadcasting. In the training setting i noticed that present callers continue asking questions to the person that has left but of which the last frame is fronzen and present.
In a multi view I have not found an easy way to remove the image or cover it up per layer with a color or image via shortcuts. Has anybody easily replaced layers in a multi view with a shortcut. If so, that would solve some of the pain related to this point.
Help is welcome.
Greetz Wilko
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
A few ideas. Create a shortcut to remove that particular overlay, and one to re-enable if needed later. Or have a shortcut add an image above the PIP from another input. That would require a shortcut for each pip, makes it a lots easier of you're using Streamdecks. Myself, I just am careful about the order of callers, so if someone has to leave, I make sure they are #8, then #7, etc, so that I can then switch to 7 PIP input, and on. Here is what my PIP setup looks like: https://vimeo.com/413367094
Originally Posted by: Wilko  In a multi view I have not found an easy way to remove the image or cover it up per layer with a color or image via shortcuts. Has anybody easily replaced layers in a multi view with a shortcut. If so, that would solve some of the pain related to this point.
From Shortcut Help (index=layer}: MultiViewOverlayToggle On/Off MultiView Overlay For Input At Index (starting from 1) Value = Index ParametersValue,Input
Thanks for the great ideas. Conclusion.....vMix is so versatile. Thanks for the help!
Regards Wilko
vMix Call
