bambarbiatv
#1 Posted : Friday, May 1, 2020 10:16:29 PM(UTC)
bambarbiatv
Ukraine
I can’t distribute audio on one PC. Output 1: Audio moderator+studio speaker - all OK. Output 2: I need audio of simultaneous translation with the mixed sound of the studio speaker (recording and stream). See picture.
No function to record audio Bus A+B (without master). If record audio MAB - the sound of the speaker at the same level with simultaneous audio translation. Any thoughts? And second, if simultaneous translation is not needed, how can I automatically raise the moderator's voice level from inter-noise to normal? Thank's
TobinT
#2 Posted : Saturday, May 2, 2020 10:10:13 PM(UTC)
TobinT
Was thanked: 11 time(s) in 11 post(s)
For the audio routing try this. In Outputs/NDI/SRT settings menu turn on Audio Outputs in the additional NDI outputs section. You can then bring those NDI outputs back into Vmix as inputs and route them to another Bus such as bus C. You can record then record/stream bus C which will be a A+B without M.
Hope that helps with the first issue. Not sure I've understood the second part.
thanks 1 user thanked TobinT for this useful post.
bambarbiatv on 5/3/2020(UTC)
bambarbiatv
#3 Posted : Sunday, May 3, 2020 2:42:52 AM(UTC)
bambarbiatv
Ukraine
Thank you. I will try
Kligan
#4 Posted : Friday, April 9, 2021 7:52:04 AM(UTC)
Kligan
I can't see the screenshot.
