Aric
#1 Posted : Wednesday, April 29, 2020 4:14:12 AM(UTC)
Aric
I'm hoping there's a way to do this in vMix. I currently have our slides for Sunday morning worship in picture in picture mode for the live stream setup, however when we are in church, a separate person on a different computer has the same slides, which he projects onto the large screens at the front of the church in full screen. I was wondering if there was a way to control these simultaneously in vMix so that the slides show up as picture in picture in the livestream, but also output in full screen to the projectors so that everything can be controlled from one place? I appreciate any help in figuring this out!
dmwkr
#2 Posted : Wednesday, April 29, 2020 6:13:21 AM(UTC)
dmwkr
Yes, that is possible. If you have the possibility to connect the screens to the GPU of the vMix PC, "Full Screen Output" is the way to go.
https://www.vmix.com/kno...spx/50/fullscreen-output
You are able to assign a particular input (your slides) to the Full Screen Output.
If you need the other PC for the connection to the screens, you can send the output of your slides input via NDI to the other PC (on the same network - Ethernet cable, not WLAN).
https://www.vmix.com/kno...icle.aspx/208/ndi-output
NDI Studio Monitor: https://ndi.tv/tools/
