PlayLists and multiple overlay
Joined: 4/26/2020(UTC) Posts: 5  Location: Lausanne Was thanked: 1 time(s) in 1 post(s)
Hi
I need to activate several overlay at the same time and also to change the background image with a playlist. But when I activate the second overlay, the first one disappears. Same thing if I activate a new background image, the overlay will be automatically deactivate.
Is there a way to keep overlays active until I manually deactivate them? Or do I have to create mixes for all my situations?
thanks in advance for help
Esaïe
 1 user thanked esaeberg for this useful post.
There are many more like these:
@doggy : thank for the reply but I know how to put an image on a overlay.
My problem is with the PlayList system who don't allow to keep multiple overlays at the same time (the only overlay who stay is my logo who appear with a trigger when the first image go out)
@ Esaïe
I dont understand, all overlays stay on even when the playlist is advancing to the next clip
Maybe check your trigger you mention
no, even with a clean test project I have the same problem. I just do a video with what I want and do manually and what I can do with the PlayList
I dont see a reason to have the overlay inputs in the playlist for what you want !
Originally Posted by: doggy  I dont see a reason to have the overlay inputs in the playlist for what you want ! so you do some multiple view for each step you need ?
From what i understand from the video :
you want the green and lightblue to stay overlayed (by using the overlay buttons) while the yellow and bluepurple are switched as per playlist in that case the overly inputs are not supposed to be in the playlist at all ! just the bluepurple and yellow There is no need for multiviews at all
