froylandorstad
#1 Posted : Sunday, April 26, 2020 3:45:29 AM(UTC)
froylandorstad
Norway
I've just acquired a behringer X Touch compact. I've successfully setup shortcuts and fader activators. My problem is that no matter what I try I've not been able to get any activator to work on button lights. Tryed the generic and the behringer activator. Anyone had similar problem or have a idea how I can fix it?
froylandorstad
#2 Posted : Monday, April 27, 2020 12:37:35 AM(UTC)
froylandorstad
Norway
Update. Just though I'd share my result so far.
I've managed to get the lights working with activators. But, I can not use "find" to locate buttons. If I do it's the incorrect buttons that will be addressed. The mapping on appears to be different on in and out for midi signal.
Using the software for behringer mapping I was able to figure out what numbers to use to address the correct button
The second "bug" is that I have to select "blinking" for the button to light up (it don't blink but is constant). Using normal white/ light gives no result.
Still I wish I could use both light on/off and blinking.
If anyone else use this controller, please let me know if this is just me, or goes for all.
Tone13
#3 Posted : Monday, April 27, 2020 7:06:00 AM(UTC)
Tone13
I'm not using that controller but I can't get the activator lights to work with my Stream Deck since the last vMix update......
froylandorstad
#4 Posted : Tuesday, April 28, 2020 7:23:07 AM(UTC)
froylandorstad
Norway
We have a couple of stream decks too, and can check those tomorrow.
Anyone else having problems with activators on latest update? Would be nice to know if it's just a update bug, or if I have to search for another solution.
TobinT
#5 Posted : Wednesday, April 29, 2020 12:47:24 AM(UTC)
TobinT
Was thanked: 11 time(s) in 11 post(s)
Hi, I'm using the Behringer Xtouch extender. I'm noticing some oddness with activators at the moment. If I read the activator code the Behringer buttons don't affect the correct velocities. I assume they are correct for the Behringer CMD but not for other Behringer devices. I'ms till trying to wrap my head around the activators XML.
Not having any issue with Streamdeck activators, just tested them into the default streamdeck app and they are working as is companion.
froylandorstad
#6 Posted : Thursday, April 30, 2020 7:24:15 AM(UTC)
froylandorstad
Norway
Stream deck works as normal. I've managed to get the light to blink by using the Novation LED - and set color red.... Its a strange workaround, but it does work.
xztraz
#7 Posted : Monday, May 4, 2020 10:51:21 PM(UTC)
xztraz
Sweden
+1 setting them to blinking lights them up but that's not really right :)
Guest (8)
