3rd Party Software and Development
VB Script to get Input's Audio Bus a status
Hi I am just trying to write a script that will do different things dependant on whether Audio Bus A is OFF or ON but can't seem to work out the script to get the current status of AudioBus A for Input 1. Any help would be appreciated.
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
the API xml could give you indication withing the details of an input audiobusses and details in the audio section.
Anything there that is useful to you can be used within a script
