GT
Animations menu is disabled
Joined: 4/25/2020(UTC) Posts: 3  Location: AMERICANA Thanks: 1 times
I'm trying to create a title, but every time I enter the GT, the Animations menu is disabled, not allowing me to click on it What could be happening? I'm using vmix 23.0.0.51  Capturar.PNG (69kb) downloaded 0 time(s).
@ Mensagieros
What edition of vMix are you using? VMix HD and below comes with GT Title Designer Standard (animation greyed out). VMix 4K and above comes with GT Title Designer Advanced and supports animation.
Mine is HD
Can't use this feature then?
No It also says in the top left of the designer that it's the standard version
No It also says in the top left of the designer that it's the standard version And what should I use to create animated titles?
Quote:And what should I use to create animated titles? - Upgrade the vMix license - Use legacy XAML titles (will need to learn a bit of coding manually or use Blend) - Use (buy) other title graphics software that can send your title to vMix
GT
