Joined: 4/6/2020(UTC) Posts: 20   Location: Melbourne Thanks: 1 times
Hey all I use the list function for our opener, where the anchor talks under four different pictures. We have the audio off for the pictures. But sometimes, say the second video, I'd like to have the video audio on. Is there a way to have three off but one video audio on in the same list? From what I can see you can only control the mix audio for the entire list as either on or off.
Cheers.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
maybe try with the playlist instead of list that way you can use the input settings for audio , even triggers per video played
Yeh Im aware of the playlist function, I just dont like how it requires to have so many inputs open, and can get quite confusing. We are high volume, so things are constantly updating every show. Easier to change a list than open and close inputs and then add to a playlist. But that's alright, if there's no option, I'll do it manually.
Quote:Yeh Im aware of the playlist function, I just dont like how it requires to have so many inputs open You mentioned four (4) ! one can also make a script that tests which is active and act accordingly
