Adriankey4
#1 Posted : Sunday, December 29, 2013 6:18:19 PM(UTC)
Adriankey4
Jamaica
Hello everyone
I love this software.
I have installed new converters to my pc and it has not been accepted as an input or on the PC Software for the Converter.
They are iMexx Usb Video Grabber and Analogue TV Stick Ultra and here is what I saw in vMix.
"AddNewInput
Capture Device Is Not Supported, Device Reported the following: Video YUV Out"
"AddNewInput
Capture Device Is Not Supported, Device Reported the following: Capture"
What should I do?
Adrian
thanks 1 user thanked Adriankey4 for this useful post.
shyhi3m on 12/30/2013(UTC)
Charssay
#2 Posted : Monday, December 30, 2013 3:39:59 AM(UTC)
Charssay
Hello Adrian,
Most USB Grabber device doesn't work under Vmix
Get another model brand and try again
C.
Luc Henrion
#3 Posted : Monday, December 30, 2013 4:04:57 AM(UTC)
Luc Henrion
I wouldn't say "most"... I have two, and one of them works on one laptop (XP) and the other one on another laptop (Win7).
But no one works on both. Go figure.
I would say that there are compatibility problems with some PC's or OS or both...
Which is not very surprising, given that they are very, very low-cost solutions.
Good luck !
Adriankey4
#4 Posted : Monday, December 30, 2013 12:29:13 PM(UTC)
Adriankey4
Jamaica
Ok thanks
The thing is I have been using this method for 2 years but now it's not working on my win7 pc. I use the imexx analogue tv stick ultra for two years now but my computer crashed several times with it.
Do you think because my pc hasn't been updating, could that be the problem?
Adrian
