Joined: 8/24/2019(UTC) Posts: 48  Location: Montreal Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
I have 3 shortcuts that are toggling 3 different inputs on the output number that I have assigned to Vimix Call - Caller 01. One is a PPT presentation the other a 2x split screen and the third one is the preview window.
My problem here is that I can't find a way to monitor which one he is currently seeing. I though about assigning the current output used on the Vmixcall (output4 in my case)to a layer in a custom input multiview, That way I could see the Thumbnail change to the selected one but "outputs" are not available in the 10 layer choices...
I know this might not be super clear, but any ideas ?
-L
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
If you enable NDI for output 4 in the vMix settings you can add it again as an NDI input.
Originally Posted by: dmwkr  If you enable NDI for output 4 in the vMix settings you can add it again as an NDI input. Brilliant, I never really had any use for NDI so it never even crossed my mind. Ill try it out later tonight ! In the mean time I have found a way to have a title change in text value when the corresponding shortcut is triggered. I used a huge white font the thumbnail's black background .... It works. -L
