Change camera input settings without closing and adding new input
Is it possible to change a camera input settings without closing it and adding a new one and losing my trigger settings?
Joined: 11/9/2014(UTC) Posts: 105 Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 16 time(s) in 15 post(s)
Absolutely. You can use the "change" button.
1. doubleclick/click the cog wheel on the desired camera input 2. click the "change" button found in the "general" tab 3. confirm that the input will be stopped tempoarily
That's it :)
I hope that helps
That's it :)
I hope that helps I had previously tried that once, but it causes vMix to hang. I'll try again. Thanks!
This has been working for me now, I'm not sure why it failed the first time, could be the updated drivers for the USB input that also fixed another issue.
