Joined: 9/17/2019(UTC) Posts: 13  Location: Richmond, VA Was thanked: 2 time(s) in 2 post(s)
Is there a way to fade out all the overlay channels at once? Perhaps using a shortcut. I know there is one that will cut them all off at once, but looking for a dissolve option.
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: mjbrad11  Is there a way to fade out all the overlay channels at once? Perhaps using a shortcut. I know there is one that will cut them all off at once, but looking for a dissolve option. use the same key for shortcut key to fade each one individually at the same time
Thank you. That's perfect. I didn't know you could use the same key for multiple shortcuts.
