Buzzjunkie
#1 Posted : Wednesday, April 22, 2020 1:56:43 AM(UTC)
Buzzjunkie
Denmark
Here's the scenario: I am producing a livestream show with up to 6 people taking part, each from their own camera/webcam (still trying to find a suitable platform for a broadcast mixer to integrate best). In the show I need to be able to mix/switch between those people so sometimes they are all visible, sometimes it might just be 2, then 3 - and it might be a different combination of people each time - and the show is not rehearsed, so cannot be preset. Is there any function in VMIX that allows me to easily (single/double-click) add and remove inputs from the program window on the fly without creating every single possible variable in separate layered inputs beforehand?
I hope that's clear!!
Thanks in advance for your help
#2 Posted : Wednesday, April 22, 2020 2:05:19 AM(UTC)
Check the helpfiles , especially the shortcut functions reference part or just check the create shortcut within vMix to see all the posibilities
(AddInput / RemoveInput for example)
Buzzjunkie
#3 Posted : Wednesday, April 22, 2020 2:07:35 AM(UTC)
Buzzjunkie
Denmark
Cheers. I'll take a look at those.
