Animatic
#1 Posted : Tuesday, April 21, 2020 5:24:27 AM(UTC)
Animatic
If I bring in a small graphic ie: a 400px X 300px logo, it automatically scales and stretches it to 1920x1080.
I then have to go into the input settings and re-scale it back down while also trying to restore the original aspect ratio.
One work around using a program like Photoshop to place the logo on a 1920 x 1080 transparent PNG already pre-positioned and scaled.
It seems like there should be away to import a graphic with out needing to scale it or pre-compose it in PS.
Sorry if this has been asked before (seems like it would have been).
I did searched the forum but couldn't find an answer.
Thanks all!
Kevin
ask
#2 Posted : Tuesday, April 21, 2020 7:34:53 AM(UTC)
ask
Animatic
#3 Posted : Tuesday, April 21, 2020 7:45:21 AM(UTC)
Animatic
I tried all 4 choices.
They do change the Aspect Ratio but none of the display the graphic correctly and it's still scaled up to 1920x1080
ask
#4 Posted : Tuesday, April 21, 2020 7:54:11 AM(UTC)
ask
Animatic
#5 Posted : Tuesday, April 21, 2020 8:17:23 AM(UTC)
Animatic
Yes. Thank you.
That is the way I usually adjust the scaling.
Just seems like you should be able to bring in the logo in it's original size.
Thought I was doing something wrong.
Maybe a feature request:
Under General
Scaling: (Have two choices)
Normal or Source
Thanks for the reply
-Kevin
