Feature Requests
Powerpoint - Variable slide times
I really would like the possibility the change the timing for each slide with a powerpoint input. Or, use the timings created in Powerpoint itself (or both).
At this point, it's only possible to setup a fixed timing.
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
Did you know that you can present the slides online (build into powerpoint itself) and ingest it as http webpage in vmix. This way you have all animations, fonts and timings correct.
Feature Requests
