witsok
#1 Posted : Monday, April 20, 2020 11:02:12 PM(UTC)
witsok
My vMix HD ver is 21.
I need to host 3 callers using Zoom.
To set it up I followed instructions from vMix website
https://www.vmix.com/kno...x-from-the-same-computer
As a result I managed to get this in Zoom:
On the left there's my cell phone cam.
On the right there's my output from vMix.
On my phone screen I can see the output from vMix too.
Sound is ok.
The problem is I can't get video output from Zoom to vMix.
No matter what I add (display1 etc) I get the same as in the picture.
(my cam on the left and vmix output on the right)
What am I doing wrong?
Witold
mavik
#2 Posted : Tuesday, April 21, 2020 5:43:43 AM(UTC)
mavik
You do nothing wrong. You capture display1 and get what you see in zoom. Create a virtual input from the input and crop to the section you are interested in. You may get into a invinite video loop if you feed back what you get.
In general I would recommend one of the two methods.
#1 Zoom as master. vmix as client (sorce). In this case zoom is the center of all actions and you "just" feed as if you were a normal webcam participant.
#2 vmix as master, zoom as client (sorce). You pick up the zoom guest and send out a mixture of all your sources to a streaming server.
Did you know that zoom can directly stream to a rtmp target.
witsok
#3 Posted : Tuesday, April 21, 2020 6:10:15 AM(UTC)
witsok
Thanks. So I'm doing #2 bow, right?
vMix output is one of inputs from Zoom.
But my laptop cam is not there.
Phone cam is like another user's cam. For testing.
Should it be like that?
Speaking of rtmp stream from Zoom.
I didn't find anything like that in settings.
How can it be achieved?
ask
#4 Posted : Tuesday, April 21, 2020 7:23:35 AM(UTC)
ask
witsok
#5 Posted : Tuesday, April 21, 2020 8:43:55 AM(UTC)
witsok
OK, so it's for an extra fee.
good to know anyway.
ask
#6 Posted : Tuesday, April 21, 2020 9:17:57 AM(UTC)
ask
Fee?
witsok
#7 Posted : Tuesday, April 21, 2020 9:29:40 AM(UTC)
witsok
I thought you were talking about rtmp streams to FB and custom serwers.
That's 40 bucks per month. Am I right?
