Feature Requests
videodelay quickplay options
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
Hi Martin,
Been playing around with the videodelay and slowmotion function and would like to suggest two features for a next release:
1 be able to have a default playback slow motion speed let say 50% now its default on 100% so when you save a clip its already set to play at a set delay.
2 have a quick replay button or a selection option with quickplay to return to the last input selection automatically at the end of the clip. so when you replay a clip after its done it will return to the last input automatically.
greetings stefan
Joined: 12/2/2011(UTC) Posts: 77 Location: Europe / The Netherlands
+1 for both points incl. an option to save the motion in the preset.
Thanks: 24 times Was thanked: 10 time(s) in 8 post(s)
Feature Requests
