cwaterho
#1 Posted : Wednesday, April 15, 2020 2:50:51 AM(UTC)
cwaterho
Canada
In the process of specifying a dedicated desktop machine for a church install. (1 cam, HDMI interface, external USB Capture of audio and video). I have reviewed the reference systems and have set that as a baseline, my question is : Is it all about the video card primarily? If you were going to try and save some $ where would you do so? I was looking at the Opal setup as reference.
Chris
Kelvin
#2 Posted : Wednesday, April 15, 2020 4:28:16 AM(UTC)
Kelvin
There is also a list of system requirements (both minimum and recommended) here: https://www.vmix.com/sof.../supported-hardware.aspx
You can use it as a guide on where you can cut corners and the expected tradeoffs.
Kelvin
