KnKproductions
#1 Posted : Tuesday, April 14, 2020 10:59:36 PM(UTC)
KnKproductions
Would like to see a stand-alone window for the shortcuts, similar to the way vMix Social has its own standalone window. Would be great to open the shortcuts panel once and leave it open as its own thing vs going in and out of the settings menus to get to them. Unless there's a better way that I don't know about......
Basically would like to get access down to one or two clicks, and have the shortcuts menu stay open as its own menu that isn't intertwined with any other settings menus. Would be nice to have the activators work the same way as well, or even have the shortcuts and activators in their own intertwined group that is separate from the settings menu.
The second part: shortcut organization.
What I mean by this is when let's say one midi note is doing multiple things, there will be 5 red lines showing the repeated input.
It would be great to have an arrow ">" as a top function, or description of the total functions, that hides the repeated buttons and functions and also has it's own on/off checkbox, that we could click and have it reveal the subset of shortcuts.
This would help clean up the clutter that is caused when one button is used to do 8 things and takes 8 lines.
It's really just a way to organize shortcuts.
Example:
CONDENSED VERSION
[>].All Music and Guest Audio Off
[>].SloMo Control
EXPANDED VERSION
[v] All Music and Guest Audio Off
...[].Audio Bus A Off
...[].Intro Music off
[v] SloMo Control
...[].Dial turn left to slow speed
...[].Dial turn right to raise speed
...[].Button press for 100% speed
...[].Replay latest thing
...[].Reset input
(periods are for formatting spaces)
This is just a small example....
It'd be great to have a way to organize shortcuts.
Thanks for looking!
Gunnar
#2 Posted : Wednesday, October 28, 2020 5:45:47 AM(UTC)
Gunnar
Sweden
