cchhita
#1 Posted : Tuesday, April 14, 2020 3:01:24 PM(UTC)
cchhita
Hi there,
We have a live event that goes out to almost 3000 people every Thursday at 12pm Central US time.
This is an all staff broadcast, and over the past 3 weeks there have always been issues at around the same time in the broadcast, where vmix turns from red to orange for between 10 and 40 seconds.
The interesting thing is it is always around the same time, and I have not seen it at any other time when streaming.
We send a H2.64 1.5mpbs 720p stream up to wowza streaming engine, and it is distributed from there.
Wowza support have found some errors in our setup which they are working on, but everything I have read about in terms of this issue points to a local hardware or internet speed issue. So I wanted to see if that could be the case. I cannot rule out the cause to be Wowza Streaming Engine, My Laptop, Vmix or my internet speed. I am not clear what the logs tell me, so looking at help to decipher the logs.
I have included the relevant parts of the log below to see if that helps.
Thanks in advance
ffmpeg started on 2020-04-09 at 11:57:25
Report written to "C:\ProgramData\vMix\streaming\streaming1 20200409-115725.log"
Command line:
"D:\\vMix\\streaming\\ffmpeg2.exe" -report -rtbufsize 128M -f dshow -i "video=vMix Video YV12:audio=vMix Audio" -codec:v libx264 -s:v 1280x720 -pix_fmt:v yuv420p -threads 4 -bufsize:v 1500k -g:v 60 -preset:v veryfast -profile:v baseline -level:v 3.1 -b:v 1500k -maxrate:v 1650k -codec:a aac -b:a 128k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/23.0.0.50)" -f flv rtmps://transformation:s856RwTNsVqF@52.55.104.253:1935/live/myStream
ffmpeg version 3.3.git Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-nvenc --cpu=i686
libavutil 55. 76.100 / 55. 76.100
libavcodec 57.106.101 / 57.106.101
libavformat 57. 82.101 / 57. 82.101
libavdevice 57. 8.101 / 57. 8.101
libavfilter 6.105.100 / 6.105.100
libswscale 4. 7.103 / 4. 7.103
libswresample 2. 8.100 / 2. 8.100
libpostproc 54. 6.100 / 54. 6.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 159021.043000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 29.97 fps, 29.97 tbr, 10000k tbn, 10000k tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
[tcp @ 047d01a0] TCP Buffer has been set to 4070400 bytes
[tcp @ 047d0b20] TCP Buffer has been set to 4070400 bytes
[rtmps @ 047debc0] Ignoring unsupported var reason
[tcp @ 047d0980] TCP Buffer has been set to 4070400 bytes
frame=15655 fps= 30 q=22.0 size= 100413kB time=00:08:42.38 bitrate=1574.7kbits/s speed= 1x
frame=15671 fps= 30 q=25.0 size= 100524kB time=00:08:42.89 bitrate=1574.9kbits/s speed= 1x
frame=15686 fps= 30 q=20.0 size= 100650kB time=00:08:43.41 bitrate=1575.3kbits/s speed= 1x
frame=15701 fps= 30 q=23.0 size= 100741kB time=00:08:43.90 bitrate=1575.2kbits/s speed= 1x
frame=15716 fps= 30 q=22.0 size= 100859kB time=00:08:44.41 bitrate=1575.5kbits/s speed= 1x
frame=15731 fps= 30 q=23.0 size= 100951kB time=00:08:44.90 bitrate=1575.5kbits/s speed= 1x
[dshow @ 001d7ea0] real-time buffer [vMix Video YV12] [video input] too full or near too full (62% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 001d7ea0] real-time buffer [vMix Video YV12] [video input] too full or near too full (64% of size: 128000000 [rtbufsize parameter])! frame dropped!
frame=15747 fps= 30 q=21.0 size= 101089kB time=00:08:45.41 bitrate=1576.1kbits/s speed= 1x
frame=15747 fps= 30 q=21.0 size= 101089kB time=00:08:45.43 bitrate=1576.1kbits/s speed=0.999x
[dshow @ 001d7ea0] real-time buffer [vMix Video YV12] [video input] too full or near too full (66% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 001d7ea0] real-time buffer [vMix Video YV12] [video input] too full or near too full (69% of size: 128000000 [rtbufsize parameter])! frame dropped!
frame=15756 fps= 30 q=20.0 size= 101147kB time=00:08:45.73 bitrate=1576.1kbits/s speed=0.998x
[dshow @ 001d7ea0] real-time buffer [vMix Video YV12] [video input] too full or near too full (70% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 001d7ea0] real-time buffer [vMix Video YV12] [video input] too full or near too full (71% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 001d7ea0] real-time buffer [vMix Video YV12] [video input] too full or near too full (73% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 001d7ea0] real-time buffer [vMix Video YV12] [video input] too full or near too full (72% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 001d7ea0] real-time buffer [vMix Video YV12] [video input] too full or near too full (74% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 001d7ea0] real-time buffer [vMix Video YV12] [video input] too full or near too full (75% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 001d7ea0] real-time buffer [vMix Video YV12] [video input] too full or near too full (76% of size: 128000000 [rtbufsize parameter])! frame dropped!
frame=15765 fps= 30 q=20.0 size= 101208kB time=00:08:46.03 bitrate=1576.1kbits/s speed=0.997x
[dshow @ 001d7ea0] real-time buffer [vMix Video YV12] [video input] too full or near too full (99% of size: 128000000 [rtbufsize parameter])! frame dropped!
[dshow @ 001d7ea0] real-time buffer [vMix Video YV12] [video input] too full or near too full (100% of size: 128000000 [rtbufsize parameter])! frame dropped!
[tls @ 047d0900] Writing encrypted data to socket failed
av_interleaved_write_frame(): I/O error
[flv @ 047d9c40] Failed to update header with correct duration.
[flv @ 047d9c40] Failed to update header with correct filesize.
Error writing trailer of rtmps://transformation:s856RwTNsVqF@52.55.104.253:1935/live/myStream: I/O error
frame=16491 fps= 26 q=21.0 Lsize= 108879kB time=00:09:21.21 bitrate=1589.3kbits/s speed=0.901x
video:99371kB audio:8762kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.689630%
[tls @ 047d0900] Failed to send close message
[libx264 @ 047daf80] frame I:287 Avg QP:12.58 size: 56379
[libx264 @ 047daf80] frame P:16204 Avg QP:14.49 size: 5287
[libx264 @ 047daf80] mb I I16..4: 56.8% 0.0% 43.2%
[libx264 @ 047daf80] mb P I16..4: 2.1% 0.0% 0.3% P16..4: 13.8% 3.8% 1.4% 0.0% 0.0% skip:78.7%
[libx264 @ 047daf80] coded y,uvDC,uvAC intra: 34.0% 46.6% 26.2% inter: 5.8% 7.8% 1.1%
[libx264 @ 047daf80] i16 v,h,dc,p: 44% 51% 3% 2%
[libx264 @ 047daf80] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 32% 29% 11% 4% 5% 5% 5% 5% 4%
[libx264 @ 047daf80] i8c dc,h,v,p: 39% 42% 15% 5%
[libx264 @ 047daf80] kb/s:1451.95
[aac @ 047dd380] Qavg: 644.354
Conversion failed!
