Joined: 3/26/2020(UTC) Posts: 23   Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
Lets say I have a video that has 2 seconds of black on the head end. Is there a way to set an in-point so when I cut to the video, it plays at the 2 second (or whatever it needs to be)?
I'm hoping that when I hit "Cut" to the video, it plays without showing the black 2 seconds at the very beginning of the clip.
Thanks!
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Apparently some clips don't recognize the "Mark In" setting. Any suggestions?
I do the following: 1. Put the clip in preview 2. play, or drag the clip to the desired start point 3. Right click and choose "Mark In" 4. Send the clip to PGM and it starts at the very beginning of the file. 5. Even switching between clips doesn't work.
Note that one of the 4 clips does recognize the Marked In point, but the remaining three start at the top of the file.
I also have "Automatically Restart with Transition" Enabled on all 4 clips. Disabling this, doesn't make a difference though.
Thanks!
