GraceMaryville
#1 Posted : Monday, April 13, 2020 5:03:02 AM(UTC)
GraceMaryville
Below is the very beginning and ending of a stream we did at church on Easter. VMix showed red the entire time (no orange/yellow indicating a problem) but the stream definitely dropped for a few minutes. Can someone interpret what the error is and maybe why? Thanks!
First log file.....
ffmpeg started on 2020-04-12 at 08:52:11
Report written to "C:\ProgramData\vMix\streaming\streaming1 20200412-085211.log"
Command line:
"C:\\Program Files (x86)\\vMix\\streaming\\ffmpeg.exe" -report -rtbufsize 128M -f dshow -i "video=vMix Video YV12:audio=vMix Audio" -codec:v libx264 -s:v 1280x720 -pix_fmt:v yuv420p -threads 4 -bufsize:v 800k -g:v 60 -preset:v veryfast -profile:v baseline -level:v 3.1 -b:v 800k -maxrate:v 880k -codec:a libfaac -b:a 96k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/23.0.0.51)" -f flv "rtmp://stream.sermon.net:80/live/101416/livefor20405894_tb896_in1_vb800_ab96_fps1280x720?key=c15d03d7&rec=disk"
ffmpeg version 2.8.git Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc
libavutil 55. 2.100 / 55. 2.100
libavcodec 57. 3.100 / 57. 3.100
libavformat 57. 2.100 / 57. 2.100
libavdevice 57. 0.100 / 57. 0.100
libavfilter 6. 9.100 / 6. 9.100
libswscale 4. 0.100 / 4. 0.100
libswresample 2. 0.100 / 2. 0.100
libpostproc 54. 0.100 / 54. 0.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 123580.257000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 29.97 tbr, 10000k tbn, 29.97 tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
[tcp @ 04d07140] TCP Buffer has been set to 2240512 bytes
[libx264 @ 04d08140] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2
[libx264 @ 04d08140] profile Constrained Baseline, level 3.1
[libx264 @ 04d08140] 264 - core 144 - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 - http://www.videolan.org/x264.html - options: cabac=0 ref=1 deblock=1:0:0 analyse=0x1:0x111 me=hex subme=2 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=4 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=0 weightp=0 keyint=60 keyint_min=6 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=abr mbtree=1 bitrate=800 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=880 vbv_bufsize=800 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00
Output #0, flv, to 'rtmp://stream.sermon.net:80/live/101416/livefor20405894_tb896_in1_vb800_ab96_fps1280x720?key=c15d03d7&rec=disk':
Metadata:
encoder : Lavf57.2.100
Stream #0:0: Video: h264 (libx264) ([7][0][0][0] / 0x0007), yuv420p, 1280x720, q=-1--1, 800 kb/s, 29.97 fps, 1k tbn, 29.97 tbc
Metadata:
encoder : Lavc57.3.100 libx264
Stream #0:1: Audio: aac (libfaac) ([10][0][0][0] / 0x000A), 48000 Hz, stereo, s16, 96 kb/s
Metadata:
encoder : Lavc57.3.100 libfaac
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (libx264))
Stream #0:1 -> #0:1 (pcm_s16le (native) -> aac (libfaac))
Press [q] to stop, [?] for help
frame= 45 fps=0.0 q=30.0 size= 67kB time=00:00:01.47 bitrate= 375.5kbits/s
frame= 61 fps= 60 q=28.0 size= 102kB time=00:00:01.96 bitrate= 428.0kbits/s
frame= 76 fps= 50 q=25.0 size= 180kB time=00:00:02.49 bitrate= 592.7kbits/s
frame= 91 fps= 45 q=28.0 size= 195kB time=00:00:02.98 bitrate= 534.9kbits/s
frame= 106 fps= 42 q=26.0 size= 218kB time=00:00:03.47 bitrate= 515.1kbits/s
frame= 121 fps= 40 q=24.0 size= 246kB time=00:00:04.00 bitrate= 503.2kbits/s
frame= 137 fps= 39 q=27.0 size= 339kB time=00:00:04.49 bitrate= 617.8kbits/s
frame= 152 fps= 37 q=25.0 size= 362kB time=00:00:05.03 bitrate= 589.7kbits/s
frame= 167 fps= 37 q=24.0 size= 386kB time=00:00:05.52 bitrate= 572.3kbits/s
frame= 183 fps= 36 q=23.0 size= 415kB time=00:00:06.03 bitrate= 563.4kbits/s
frame= 198 fps= 35 q=25.0 size= 509kB time=00:00:06.54 bitrate= 636.5kbits/s
frame= 213 fps= 35 q=24.0 size= 530kB time=00:00:07.05 bitrate= 615.7kbits/s
frame= 228 fps= 35 q=23.0 size= 562kB time=00:00:07.57 bitrate= 608.4kbits/s
frame= 244 fps= 34 q=22.0 size= 588kB time=00:00:08.06 bitrate= 597.6kbits/s
frame= 259 fps= 34 q=24.0 size= 682kB time=00:00:08.57 bitrate= 651.7kbits/s
frame= 274 fps= 34 q=23.0 size= 704kB time=00:00:09.08 bitrate= 634.3kbits/s
frame= 289 fps= 33 q=22.0 size= 735kB time=00:00:09.57 bitrate= 628.7kbits/s
frame= 304 fps= 33 q=21.0 size= 764kB time=00:00:10.11 bitrate= 618.8kbits/s
frame= 320 fps= 33 q=24.0 size= 857kB time=00:00:10.60 bitrate= 662.3kbits/s
frame= 335 fps= 33 q=23.0 size= 880kB time=00:00:11.13 bitrate= 647.5kbits/s
frame= 350 fps= 33 q=22.0 size= 914kB time=00:00:11.62 bitrate= 643.9kbits/s
frame= 365 fps= 33 q=21.0 size= 946kB time=00:00:12.13 bitrate= 638.7kbits/s
frame= 381 fps= 33 q=23.0 size= 1039kB time=00:00:12.64 bitrate= 672.7kbits/s
frame= 396 fps= 32 q=22.0 size= 1061kB time=00:00:13.13 bitrate= 661.5kbits/s
frame= 411 fps= 32 q=22.0 size= 1096kB time=00:00:13.67 bitrate= 656.5kbits/s
frame= 426 fps= 32 q=21.0 size= 1130kB time=00:00:14.16 bitrate= 653.8kbits/s
frame= 441 fps= 32 q=23.0 size= 1222kB time=00:00:14.67 bitrate= 682.3kbits/s
frame= 457 fps= 32 q=22.0 size= 1242kB time=00:00:15.18 bitrate= 670.0kbits/s
frame= 472 fps= 32 q=21.0 size= 1279kB time=00:00:15.69 bitrate= 667.3kbits/s
frame= 487 fps= 32 q=21.0 size= 1315kB time=00:00:16.21 bitrate= 664.4kbits/s
frame= 503 fps= 32 q=23.0 size= 1406kB time=00:00:16.70 bitrate= 689.8kbits/s
frame= 518 fps= 32 q=22.0 size= 1430kB time=00:00:17.21 bitrate= 680.7kbits/s
frame= 533 fps= 32 q=21.0 size= 1465kB time=00:00:17.72 bitrate= 677.1kbits/s
frame= 548 fps= 32 q=21.0 size= 1499kB time=00:00:18.21 bitrate= 674.3kbits/s
frame= 563 fps= 32 q=23.0 size= 1588kB time=00:00:18.75 bitrate= 693.9kbits/s
frame= 579 fps= 32 q=22.0 size= 1614kB time=00:00:19.24 bitrate= 687.1kbits/s
frame= 594 fps= 32 q=21.0 size= 1654kB time=00:00:19.77 bitrate= 685.1kbits/s
frame= 609 fps= 32 q=21.0 size= 1683kB time=00:00:20.26 bitrate= 680.4kbits/s
frame= 624 fps= 31 q=23.0 size= 1774kB time=00:00:20.77 bitrate= 699.5kbits/s
frame= 640 fps= 31 q=22.0 size= 1799kB time=00:00:21.28 bitrate= 692.2kbits/s
frame= 655 fps= 31 q=21.0 size= 1838kB time=00:00:21.80 bitrate= 690.7kbits/s
frame= 670 fps= 31 q=20.0 size= 1869kB time=00:00:22.31 bitrate= 686.2kbits/s
frame= 685 fps= 31 q=22.0 size= 1959kB time=00:00:22.80 bitrate= 703.7kbits/s
frame= 700 fps= 31 q=22.0 size= 1982kB time=00:00:23.31 bitrate= 696.5kbits/s
frame= 716 fps= 31 q=21.0 size= 2025kB time=00:00:23.82 bitrate= 696.3kbits/s
frame= 731 fps= 31 q=20.0 size= 2057kB time=00:00:24.33 bitrate= 692.4kbits/s
frame= 746 fps= 31 q=22.0 size= 2146kB time=00:00:24.85 bitrate= 707.6kbits/s
frame= 762 fps= 31 q=22.0 size= 2174kB time=00:00:25.34 bitrate= 702.8kbits/s
frame= 777 fps= 31 q=21.0 size= 2216kB time=00:00:25.87 bitrate= 701.7kbits/s
frame= 792 fps= 31 q=20.0 size= 2242kB time=00:00:26.36 bitrate= 696.6kbits/s
frame= 807 fps= 31 q=22.0 size= 2332kB time=00:00:26.87 bitrate= 710.8kbits/s
frame= 822 fps= 31 q=22.0 size= 2362kB time=00:00:27.39 bitrate= 706.5kbits/s
frame= 838 fps= 31 q=21.0 size= 2402kB time=00:00:27.88 bitrate= 705.9kbits/s
frame= 853 fps= 31 q=27.0 size= 2431kB time=00:00:28.39 bitrate= 701.3kbits/s
frame= 868 fps= 31 q=22.0 size= 2519kB time=00:00:28.88 bitrate= 714.5kbits/s
frame= 883 fps= 31 q=21.0 size= 2546kB time=00:00:29.39 bitrate= 709.6kbits/s
frame= 898 fps= 31 q=21.0 size= 2592kB time=00:00:29.92 bitrate= 709.4kbits/s
frame= 913 fps= 31 q=27.0 size= 2617kB time=00:00:30.41 bitrate= 704.8kbits/s
frame= 928 fps= 31 q=22.0 size= 2705kB time=00:00:30.93 bitrate= 716.4kbits/s
frame= 944 fps= 31 q=22.0 size= 2740kB time=00:00:31.42 bitrate= 714.3kbits/s
frame= 959 fps= 31 q=21.0 size= 2781kB time=00:00:31.95 bitrate= 712.8kbits/s
frame= 974 fps= 31 q=20.0 size= 2805kB time=00:00:32.44 bitrate= 708.2kbits/s
frame= 989 fps= 31 q=22.0 size= 2897kB time=00:00:32.95 bitrate= 720.1kbits/s
frame= 1005 fps= 31 q=22.0 size= 2936kB time=00:00:33.47 bitrate= 718.7kbits/s
frame= 1020 fps= 31 q=21.0 size= 2972kB time=00:00:33.96 bitrate= 716.9kbits/s
frame= 1035 fps= 31 q=21.0 size= 2998kB time=00:00:34.49 bitrate= 711.9kbits/s
frame= 1050 fps= 31 q=22.0 size= 3085kB time=00:00:34.98 bitrate= 722.4kbits/s
frame= 1065 fps= 31 q=21.0 size= 3114kB time=00:00:35.47 bitrate= 719.2kbits/s
frame= 1080 fps= 31 q=21.0 size= 3159kB time=00:00:36.00 bitrate= 718.7kbits/s
frame= 1096 fps= 31 q=20.0 size= 3251kB time=00:00:36.49 bitrate= 729.6kbits/s
frame= 1111 fps= 31 q=22.0 size= 3272kB time=00:00:37.03 bitrate= 723.8kbits/s
frame= 1127 fps= 31 q=21.0 size= 3305kB time=00:00:37.52 bitrate= 721.6kbits/s
frame=131753 fps= 30 q=30.0 size= 481278kB time=01:13:16.11 bitrate= 896.8kbits/s
frame=131768 fps= 30 q=30.0 size= 481322kB time=01:13:16.62 bitrate= 896.8kbits/s
frame=131783 fps= 30 q=31.0 size= 481368kB time=01:13:17.11 bitrate= 896.8kbits/s
frame=131798 fps= 30 q=30.0 size= 481424kB time=01:13:17.63 bitrate= 896.8kbits/s
frame=131813 fps= 30 q=29.0 size= 481476kB time=01:13:18.12 bitrate= 896.8kbits/s
frame=131829 fps= 30 q=29.0 size= 481533kB time=01:13:18.63 bitrate= 896.8kbits/s
frame=131844 fps= 30 q=31.0 size= 481580kB time=01:13:19.12 bitrate= 896.8kbits/s
frame=131859 fps= 30 q=29.0 size= 481637kB time=01:13:19.63 bitrate= 896.8kbits/s
frame=131874 fps= 30 q=29.0 size= 481690kB time=01:13:20.12 bitrate= 896.8kbits/s
frame=131889 fps= 30 q=29.0 size= 481754kB time=01:13:20.63 bitrate= 896.8kbits/s
av_interleaved_write_frame(): Unknown error
[flv @ 04d071c0] Failed to update header with correct duration.
[flv @ 04d071c0] Failed to update header with correct filesize.
frame=131893 fps= 30 q=30.0 Lsize= 481770kB time=01:13:20.78 bitrate= 896.8kbits/s
video:429665kB audio:46110kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 1.260181%
[libx264 @ 04d08140] frame I:2202 Avg QP:22.05 size: 43177
[libx264 @ 04d08140] frame P:129691 Avg QP:23.00 size: 2660
[libx264 @ 04d08140] mb I I16..4: 70.3% 0.0% 29.7%
[libx264 @ 04d08140] mb P I16..4: 3.8% 0.0% 0.0% P16..4: 12.7% 1.7% 0.3% 0.0% 0.0% skip:81.5%
[libx264 @ 04d08140] coded y,uvDC,uvAC intra: 28.4% 60.3% 34.9% inter: 2.5% 7.1% 0.2%
[libx264 @ 04d08140] i16 v,h,dc,p: 53% 24% 17% 5%
[libx264 @ 04d08140] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 25% 14% 6% 6% 6% 8% 5% 8%
[libx264 @ 04d08140] i8c dc,h,v,p: 61% 22% 14% 3%
[libx264 @ 04d08140] kb/s:799.92
Conversion failed!
...and then the next log file when the stream comes back....
ffmpeg started on 2020-04-12 at 10:05:52
Report written to "C:\ProgramData\vMix\streaming\streaming1 20200412-100552.log"
Command line:
Duration: N/A, start: 128001.052000, bitrate: 1536 kb/s
[tcp @ 04fbac20] TCP Buffer has been set to 2240512 bytes
[libx264 @ 04fb8080] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2
[libx264 @ 04fb8080] profile Constrained Baseline, level 3.1
[libx264 @ 04fb8080] 264 - core 144 - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 - http://www.videolan.org/x264.html - options: cabac=0 ref=1 deblock=1:0:0 analyse=0x1:0x111 me=hex subme=2 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=4 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=0 weightp=0 keyint=60 keyint_min=6 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=abr mbtree=1 bitrate=800 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=880 vbv_bufsize=800 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00
Metadata:
Metadata:
Metadata:
Stream mapping:
frame= 44 fps=0.0 q=30.0 size= 81kB time=00:00:01.44 bitrate= 458.1kbits/s
frame= 59 fps= 58 q=29.0 size= 136kB time=00:00:01.96 bitrate= 569.9kbits/s
frame= 74 fps= 49 q=32.0 size= 186kB time=00:00:02.47 bitrate= 617.6kbits/s
frame= 90 fps= 44 q=30.0 size= 255kB time=00:00:02.96 bitrate= 706.1kbits/s
frame= 105 fps= 42 q=30.0 size= 310kB time=00:00:03.47 bitrate= 730.1kbits/s
frame= 120 fps= 40 q=30.0 size= 364kB time=00:00:03.96 bitrate= 751.4kbits/s
frame= 135 fps= 38 q=31.0 size= 405kB time=00:00:04.45 bitrate= 744.2kbits/s
frame= 150 fps= 37 q=29.0 size= 469kB time=00:00:04.99 bitrate= 769.2kbits/s
frame= 166 fps= 36 q=29.0 size= 526kB time=00:00:05.48 bitrate= 786.5kbits/s
frame= 181 fps= 36 q=32.0 size= 611kB time=00:00:05.99 bitrate= 835.0kbits/s
frame= 196 fps= 35 q=30.0 size= 659kB time=00:00:06.48 bitrate= 833.3kbits/s
frame= 211 fps= 35 q=30.0 size= 712kB time=00:00:06.99 bitrate= 833.7kbits/s
frame= 226 fps= 34 q=30.0 size= 770kB time=00:00:07.50 bitrate= 840.2kbits/s
frame=47782 fps= 30 q=28.0 size= 174632kB time=00:26:34.30 bitrate= 897.3kbits/s
frame=47797 fps= 30 q=27.0 size= 174638kB time=00:26:34.81 bitrate= 897.1kbits/s
frame=47812 fps= 30 q=26.0 size= 174641kB time=00:26:35.30 bitrate= 896.8kbits/s
frame=47827 fps= 30 q=25.0 size= 174655kB time=00:26:35.79 bitrate= 896.6kbits/s
frame=47842 fps= 30 q=24.0 size= 174656kB time=00:26:36.30 bitrate= 896.3kbits/s
frame=47857 fps= 30 q=23.0 size= 174657kB time=00:26:36.79 bitrate= 896.0kbits/s
frame=47872 fps= 30 q=43.0 size= 174733kB time=00:26:37.33 bitrate= 896.1kbits/s
frame=47887 fps= 30 q=34.0 size= 174796kB time=00:26:37.82 bitrate= 896.2kbits/s
frame=47903 fps= 30 q=30.0 size= 174836kB time=00:26:38.33 bitrate= 896.1kbits/s
frame=47918 fps= 30 q=30.0 size= 174866kB time=00:26:38.82 bitrate= 896.0kbits/s
frame=47933 fps= 30 q=30.0 size= 174930kB time=00:26:39.31 bitrate= 896.0kbits/s
frame=47948 fps= 30 q=29.0 size= 174933kB time=00:26:39.82 bitrate= 895.8kbits/s
frame=47963 fps= 30 q=28.0 size= 174940kB time=00:26:40.33 bitrate= 895.5kbits/s
frame=47978 fps= 30 q=27.0 size= 174949kB time=00:26:40.85 bitrate= 895.3kbits/s
frame=47993 fps= 30 q=28.0 size= 175037kB time=00:26:41.34 bitrate= 895.4kbits/s
frame=48008 fps= 30 q=27.0 size= 175039kB time=00:26:41.85 bitrate= 895.2kbits/s
frame=48023 fps= 30 q=26.0 size= 175043kB time=00:26:42.34 bitrate= 894.9kbits/s
frame=48038 fps= 30 q=25.0 size= 175051kB time=00:26:42.85 bitrate= 894.7kbits/s
frame=48053 fps= 30 q=26.0 size= 175140kB time=00:26:43.36 bitrate= 894.8kbits/s
frame=48068 fps= 30 q=25.0 size= 175148kB time=00:26:43.85 bitrate= 894.6kbits/s
frame=48083 fps= 30 q=24.0 size= 175153kB time=00:26:44.37 bitrate= 894.3kbits/s
frame=48099 fps= 30 q=29.0 size= 175258kB time=00:26:44.86 bitrate= 894.6kbits/s
frame=48114 fps= 30 q=24.0 size= 175264kB time=00:26:45.37 bitrate= 894.3kbits/s
frame=48129 fps= 30 q=23.0 size= 175266kB time=00:26:45.86 bitrate= 894.1kbits/s
frame=48144 fps= 30 q=22.0 size= 175282kB time=00:26:46.37 bitrate= 893.9kbits/s
frame=48159 fps= 30 q=21.0 size= 175284kB time=00:26:46.88 bitrate= 893.6kbits/s
frame=48174 fps= 30 q=20.0 size= 175285kB time=00:26:47.37 bitrate= 893.3kbits/s
frame=48189 fps= 30 q=19.0 size= 175287kB time=00:26:47.89 bitrate= 893.1kbits/s
frame=48204 fps= 30 q=18.0 size= 175307kB time=00:26:48.38 bitrate= 892.9kbits/s
frame=48219 fps= 30 q=17.0 size= 175309kB time=00:26:48.89 bitrate= 892.6kbits/s
[flv @ 04fb7280] Failed to update header with correct duration.
[flv @ 04fb7280] Failed to update header with correct filesize.
frame=48234 fps= 30 q=-1.0 Lsize= 175311kB time=00:26:49.44 bitrate= 892.3kbits/s
video:155668kB audio:17448kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 1.267894%
[libx264 @ 04fb8080] frame I:813 Avg QP:22.13 size: 36402
[libx264 @ 04fb8080] frame P:47421 Avg QP:24.07 size: 2737
[libx264 @ 04fb8080] mb I I16..4: 73.8% 0.0% 26.2%
[libx264 @ 04fb8080] mb P I16..4: 4.6% 0.0% 0.0% P16..4: 12.9% 2.3% 0.4% 0.0% 0.0% skip:79.9%
[libx264 @ 04fb8080] coded y,uvDC,uvAC intra: 23.7% 54.1% 29.2% inter: 2.5% 6.9% 0.1%
[libx264 @ 04fb8080] i16 v,h,dc,p: 50% 27% 17% 6%
[libx264 @ 04fb8080] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 30% 16% 5% 6% 5% 8% 4% 8%
[libx264 @ 04fb8080] i8c dc,h,v,p: 62% 23% 13% 3%
[libx264 @ 04fb8080] kb/s:792.36
#2 Posted : Monday, April 13, 2020 9:38:06 PM(UTC)
@ GraceMaryville
You may want to review these articles in the vMix Knowledge base:
- https://www.vmix.com/kno...ng-ffmpeg-streaming-logs
- https://www.vmix.com/kno...gnosing-streaming-errors
In particular:
This error means the stream has disconnected which can occur for one of the following reasons:
1. Local internet outage
2. Streaming provider internet outage
3. Streaming provider has closed the stream for some reason
