Start stream 1 & 2 with single shortcut?
I see with the start/stop stream shortcut we can specify which stream to start/stop but can I specify 2? I tried to comma delimit (0,1) but it didn't work.
Funny enough there are helpfiles
for example:
StartStopStreaming
Optional stream number starting from 0. Leave blank to control all streams.
Maybe try that
Funny, that doesn't help as I want to only start streams 0 & 1 of the 3 streams, not all of them.
If the third one is set to none it won't do a thing anyway
On the other hand one can combine shortcuts , meaning several functions under the same key So one shortcut for the first, another for the second but both under the same key
I see, a shortcut can trigger other shortcuts. That'll work, thanks!
