Sdepace
#1 Posted : Saturday, April 11, 2020 1:41:22 AM(UTC)
Sdepace
I've made a script mapped to a shortcut using the AddInput function, allowing me to import an edited video with a preset name. Is there any way to automatically uncheck the "automatically mix audio" and uncheck the "automatically pause after transition" or do I have to do it manually everytime?
krassesPferd
#2 Posted : Saturday, April 11, 2020 2:11:30 AM(UTC)
krassesPferd
Was thanked: 8 time(s) in 7 post(s)
You can set the behavior for new added inputs in vMix global settings.
https://www.vmix.com/hel...m?StreamingSettings.html
dmwkr
#3 Posted : Saturday, April 11, 2020 2:15:59 AM(UTC)
dmwkr
Try to add the AudioAutoOff and AutoPauseOff functions to your script.
In the vMix settings there is also the option to change the default setting for the pause.
Sdepace
#4 Posted : Saturday, April 11, 2020 4:43:26 AM(UTC)
Sdepace
Thanks I changed the pause setting, however I still want "auto mix audio on" in audio settings. What would the script function for turning off the auto mix be, so that I could turn it off just for that clip?
dmwkr
#5 Posted : Saturday, April 11, 2020 5:01:47 AM(UTC)
dmwkr
The function is AudioAutoOff
Sdepace
#6 Posted : Saturday, April 11, 2020 5:08:51 AM(UTC)
Sdepace
Thanks for your help, although I still can't get it to work. Very new to scripting! Here's what I have, which imports the video but with Auto mix still turned on.
Function=AddInput&Value=Video|X:\TO VMIX\Edit1.mov
Function=AudioAutoOff
Am I missing something?
dmwkr
#7 Posted : Saturday, April 11, 2020 5:44:36 AM(UTC)
dmwkr
You have to specify the input, and before wait a second or two until the input is loaded.
Sleep 2000
Function=AudioAutoOff&Value=Edit1.mov
Congrats on starting with scripting! I'm also still in the early stages, learning and it is fun, and helpful.
There's a great tool by Richard to build scripts and learn:
https://forums.vmix.com/...r-App---Updated-02-24-20
Keep it up!
Sdepace
#8 Posted : Saturday, April 11, 2020 6:09:36 AM(UTC)
Sdepace
Thanks but still not working. I was able to another shortcut which does the AudioAutoOff function and that works but not ideal.
Sdepace
#9 Posted : Saturday, April 11, 2020 6:33:07 AM(UTC)
Sdepace
OK I figured it out using the editor. Thanks!
Sdepace
#10 Posted : Tuesday, April 14, 2020 1:12:41 AM(UTC)
Sdepace
OK next question, same subject from a newbie scriptbuilder. Throughout our show we have videos that an editor posts and I import into VMIX. I previously as per forum above, set up three scripts to import the edits named Edit 1, Edit 2 and Edit 3 with the desired audio settings. It seems that there will be additional edits moving forward, so I wondered if there was a better way to do it.
Is there a way where any new edit in a watch folder would automatically import into VMIX with the correct playback settings? Or perhaps If I manually drag in the edits as new inputs, is there a way to have one script change the playback settings (AudioOn and AudioAutoOff) for the last input or previewed input? Would that be some sort of Dynamic input?
I really appreciate any help on this.
#11 Posted : Tuesday, April 14, 2020 1:40:04 AM(UTC)
this could give some ideas
https://www.vmix.com/kno...ding-to-vmix-as-an-input
Sdepace on 4/14/2020(UTC)
Sdepace
#12 Posted : Tuesday, April 14, 2020 2:43:58 AM(UTC)
Sdepace
Thanks. That helps. So I took that and it works, but I'm having trouble adding the AudioAutoOff and AudioOn. I guess I'm not sure how to write the code in VB.net scripting, only web scripting. I got it to work, but only when I know the specific input number. Here is what I have:
Dim szExt As String = ".mov"
Dim szFolder As String ="X:\TO VMIX"
Dim szLatestFile As String = ""
Dim dLatestFile As Date = Nothing
For Each szFile As String In System.IO.Directory.GetFiles(szFolder)
Dim fi As New System.IO.FileInfo(szFile)
If fi.Extension = szExt Then
If fi.LastWriteTime > dLatestFile Then
szLatestFile = szFile
dLatestFile = fi.LastWriteTime
End If
End If
Next
If System.IO.File.Exists(szLatestFile) Then
API.Function("AddInput", Value:="Video|" & szLatestFile)
Sleep(2000)
API.Function("AudioAutoOff", Input:=62)
API.Function("AudioOn", Input:=62)
End If
Any ideas how to complete this script?
#13 Posted : Tuesday, April 14, 2020 3:02:37 AM(UTC)
Just a though.
think you might need to add some logic the search for the added input from the API xml to get the input number or so ?
Overall with all the things you want done it might be better to have an external script as invMix scripts do not allow for subroutines and internal functions etc
From there its much easier to give vMix instructions with httprequests
as said just a thought
Sdepace
#14 Posted : Tuesday, April 14, 2020 3:52:23 AM(UTC)
Sdepace
OK with my son's help, we figured it out! Thanks for your help as well.
If interested, here's the code to import the latest video with AudioAutoOff and AudioOn:
End If
End If
Next
Sleep(500)
Console.WriteLine(szLatestFile.substring(11))
Input.Find(szLatestFile.substring(11)).Function("AudioAutoOff")
Input.Find(szLatestFile.substring(11)).Function("AudioOn")
'API.Function("AudioAutoOff", Input:=62)
'API.Function("AudioOn", Input:=62)
End If
thanks 1 user thanked Sdepace for this useful post.
Ario on 1/6/2023(UTC)
