Control audio mixer channels
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hi, question is any way that vmix control each channel of a audio mixer? is possible how can be done and what audio mixer, thanks for you help
Don't understand your question correct Do you mean hardware to control vMix audio channels? if yes : Behringer BCF2000 works very well, a little bit difficult to configure, but if it's done, it works
Originally Posted by: xaver  Don't understand your question correct Do you mean hardware to control vMix audio channels? if yes : Behringer BCF2000 works very well, a little bit difficult to configure, but if it's done, it works sorry, yes I want to be able to control from vmix an external audio mixer, will like to control each mic if that is possible, thanks
Joined: 4/23/2017(UTC) Posts: 1,449  Location: Germany Thanks: 3 times Was thanked: 192 time(s) in 172 post(s)
That would require a mixer that understands commands over IP and has motor faders. Otherwise touchiing the faders would create audio jumps. You might want to look more into the installation sector. Usually people buy mixers to have the faders and knobs available. I use a Behringer XR 18. It's more or less a breakoutbox and you do everything on a screen (desktop or mobile). But you can't control it from vMix interface. At least not to my knowledge.
Originally Posted by: xaver  Don't understand your question correct Do you mean hardware to control vMix audio channels? if yes : Behringer BCF2000 works very well, a little bit difficult to configure, but if it's done, it works Hello Xaver! Could you share your BCF2000 Template? Its very difficult to find how to make it work. Thank you in advance. Regards.
Joined: 6/11/2020(UTC) Posts: 16  Location: San Francisco Was thanked: 5 time(s) in 4 post(s)
I recently hooked up a USB nanoKONTROL2 and that works well. It connects like any other midi device and you can assign gain to the know and volume to the fader. I assigned Solo to the S button on each fader and 2 other buttons, M and R can be used for whatever you program them with.
8 faders and some additional player function buttons you can program to do whatever as well.
Pretty solid device for $60.
Hola,
tengo una consola BCF2000, pero soy muy necio configurando cosas. ¿Podrías pasarme tu plantilla de configuración?. Muchisimas gracias por tu ayuda. saludos
Hello there,
I have a BCF2000 console, but I am very stupid setting things up. Could you pass me your configuration template? Thank you very much for your help.
Cheers
