vMix Call
vMixRemote Beta Test - Making vMix Call entrance experience easier
Was thanked: 5 time(s) in 1 post(s)
This is a personal effort as I've found it challenging to coordinate non-technical guests joining vMix Calls, but developed it so anyone can use it. Throwing it out here in case it's useful for anyone else. Problems: - It's been a lot of trouble/effort to establish a vMix Call for each remote guest, keep track of their vmix.at URL, and text it to each guest individually - When calls / inputs change, it's difficult to get the remote guest to switch to a new call code, and they start to feel that it's too complicated or get frustrated So I put together an experience that seeks to make this better: - Creates 1 link that can be shared with all guests at once - Assigns guests to the next available vMix Call input - Holds guests in a "waiting" state if vMix is not running yet or if there are not enough available inputs - Asks only for their name and doesn't confuse them with a password/call code This is accomplished by running a "vMix Remote Agent" app that talks to vMix via the local API, and keeps the cloud side updated with the current inputs available in vMix. Available here: https://vmix.brandonpotter.com
 5 users thanked bpiddy for this useful post.
Joined: 4/23/2017(UTC) Posts: 1,491  Location: Germany Thanks: 3 times Was thanked: 198 time(s) in 178 post(s)
Hey, just installed your software and I am getting "Error: Error communicating with vMix (may not be started". vMix is started. Any tips for troubleshooting? Looks like it could be super cool, thanks for sharing!
-Aaron
Originally Posted by: Kovacika  Hey, just installed your software and I am getting "Error: Error communicating with vMix (may not be started". vMix is started. Any tips for troubleshooting? Looks like it could be super cool, thanks for sharing!
-Aaron It's trying to query the vMix API via localhost:8088/api/? So you might get that error message if you have changed that port or whatever in vMix Settings > Web Controller.
API is enabled on port 8088. I can access it via a browser.
Originally Posted by: Kovacika  API is enabled on port 8088. I can access it via a browser. Interesting, just double checked code and the exact URL it's trying to get is: http://127.0.0.1:8088/api/ Are you able to reach that in a browser with no authentication and get a valid XML response?
Yep, no issues getting to that address, or localhost.
Hmm, weird. I just uploaded v1.0.1 that displays a more explicit error when it can't reach vMix. Can you redownload and see if that provides more info?
System.InvalidOperationException There is an error in XML document (1, 1246).
Originally Posted by: Kovacika  System.InvalidOperationException There is an error in XML document (1, 1246). Ah! So it's reaching the API but can't parse the response. What version of vMix are you on? If you access it in browser, does the response start with ? Also do you have any HTTP proxies enabled on your machine that might be intercepting and returning a different response?
Using vMix 23.0.0.50. No proxies. When I access in browser the response starts with the version #, then show name, then shortcuts<--I lied, inputs, not shortcuts.
Just tried on another machine running 23.0.0.46, works great. Might be a .50 issue?
Originally Posted by: Kovacika  Just tried on another machine running 23.0.0.46, works great. Might be a .50 issue? Ah! I'm on 49, you might be right - maybe there's an API change in 50. Will try 50 later and see what happens...
Do you have any plans to release the webserver/backend portion of this? I would love to be able to build custom landing pages and have custom URLs. A way to include a password to prevent unauthorized access would be good too. Id even be happy to pay if I got those features.
Joined: 5/6/2016(UTC) Posts: 83  Was thanked: 5 time(s) in 5 post(s)
Same problem on .50 unfortunately.
I haven't specifically checked, but there were some vmix call changes made in the most recent versions. For instance, the peer-to-peer only option.
Not sure if that's exposing itself via API. If so, .50 may be presenting some new data via API that your app is unprepared for?
Anyhow, very curious to check this out once you get it resolved.
Thanks!
Joined: 12/14/2018(UTC) Posts: 88  Was thanked: 18 time(s) in 7 post(s)
Tested on .50, it does not work either. But will wait ;)
grega
.50 should be fixed now (requires re-downloading the remote agent)
Some types in the XML weren't mapped correctly that I guess .50 started using.
Originally Posted by: Kovacika  Do you have any plans to release the webserver/backend portion of this? I would love to be able to build custom landing pages and have custom URLs. A way to include a password to prevent unauthorized access would be good too. Id even be happy to pay if I got those features. Couple things here -- 1) Not necessarily opposed to either releasing/open sourcing the backend or allowing customization of the landing page HTML. Now that the .50 bug is (hopefully) out of the way, I'll certainly give this some thought! 2) Interesting you brought up the password topic/feedback - I was going for a high-entropy "just works" URL, so that it's more or less un-guessable (or at least a lot less guessable than the vMix Call passwords themselves), and the only thing a caller needs to do is click a link and not worry about anything else, then you can reset the keys/URLs after your event is over to invalidate the links for that event/day. Curious what use case(s) make a password add value here.. Awesome feedback - thanks! B
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
Just tried it and i'm impressed!
The only thing that i see as a problem is the timeout of a ended call. But probably that's a internal vmix problem.
Really nice job! Also wiling to see a package for deploying your own customized instance!
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
Hi the idea is great, but still crash at least in the only machine that i have now online (.51), connect to api work and stop and work again.
vMix Call
