2 Pages<12
ELCHAPIN
#21 Posted : Friday, August 12, 2011 2:04:08 AM(UTC)
ELCHAPIN
hi all
also given me a little complication.
recommended would be to put only a number of continuity based on the basic name attached.
The wedding _ _001
The wedding _ _002
The Wedding _ _003
the regular order, I always think filming new folder by event
(Sunday August 14 example)
The most important thing in my case, do not lose quality or Frames.
I learned to make the audio separately and all good.
I like to have full quality DV AVI type.
continue to see more from the forum
thanks
omnisound
#22 Posted : Friday, August 12, 2011 3:45:33 AM(UTC)
omnisound
Hi Melody. I confirm my problem. You must see the 2 last files. The hour of windows is the good hour and in the name of this file it's the hour of the precedent file. If you see the duration of the file before the last it's 1'43 and the windows hour (who is correct!) is 17:47. Now if you see the last file, the hour in his name is 05-47-33 (17:47) but I'm sure the last file has created at 18:03. There is more than 1'43 between the name and the windows hour on the last file. The problem is not the start or final hour of recording.
Please admin can you give us your opinion !
regards.
Loïc
Guest (5)
2 Pages<12
