Instagram and Facebook at the same session
I have a question to stream to Facebook and Instagram at the same time. The problem is the format. I use to stream to Facebook 16:9 and for Instagram 9:16. I want to use Stream 1 for Facebook and stream 2 for Instagram, but i use the same input. Is it possible to transform the video (rotate 90°) only for the stream 2?
Thank you for your answers. Jens
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ WalkoMedia
- Send Program Output to Output3 - Add Output3 as NDI Input in vMix - Rotate that new Input's Position with Z slider and Zoom accordingly - Send that Input to Output2 - Set Stream2 to Output2 with Aspect Ratio/Crop to 9:16
Hallo Ice,
because I'm beginner of vMix, we have only hardware mixers, I bought only basic HD. In this version it is no possible to "send that Input to Output2".I think so.
"The Cog Button contains a drop down menu for selecting a source for any additional outputs in real time (Available in vMix 4K and Pro)"
It`s right or I don`t found it?
Greetings Jens
Joined: 3/23/2020(UTC) Posts: 139  Location: Washington, DC Thanks: 41 times Was thanked: 25 time(s) in 17 post(s)
I don't think you can stream to Instagram.
@ WalkoMedia,
Yes, you need vMix 4K or vMix Pro (or the Trial) to access the additional Outputs. Sorry that I did not qualify that in my above post.
