vMix Call
Beware of homeworkers VPN hindering vMix Call
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
During the Corona crisis a lot of our clients are working from home. We have noticed that many tend to be connected via VPN into their corporate network, which in turn have firewalls that prohibits the use of ports necessary for vMix Call. Easy fix is to ask the howeworker to disable their VPN when they participate in a vMix Call session. More complicated fix is to ask the network admin to open the firewall, see https://www.vmix.com/kno...ll-firewall-requirements
 1 user thanked richardgatarski for this useful post.
Joined: 3/29/2020(UTC) Posts: 3  Location: Somerset, MA Thanks: 3 times
Good point. I have been testing with three to four call participants and getting a lot of latency. I have since made the changes to the network based on that link, but after setting, does vcall NOT use the default 10349 anymore? I had figured our calls were getting delayed by routing, so does using these other ports make the vcall "smarter" and it does not use 10349 if you have the others available?
S
Joined: 1/13/2010(UTC) Posts: 5,212  Location: Gold Coast, Australia Was thanked: 4530 time(s) in 1572 post(s)
10349 is the port of our servers, so if that is the only port open in the firewall, the call is forced to use our servers rather than directly. Direction connections can use a random UDP port in the range specified in the knowledge base article, so allowing outbound UDP without restriction is the best way to ensure good call quality. (which is what pretty much all residential modem/routers do, it is only corporate firewalls with very restrictive policies where UDP is completely blocked that tend to cause the most issues)
Joined: 4/23/2017(UTC) Posts: 1,346  Location: Germany Thanks: 3 times Was thanked: 178 time(s) in 160 post(s)
I have made very good experiences with using a mobile phone with larix broadcaster over SRT. Most users can even use 4G data plans for short transmissions. And phones are not that much restricted.
 1 user thanked mavik for this useful post.
I am having issues with the Larix approach....in most cases, have defaulted back to vmixcall approach. Looking to get least CPU intensive approach...does anyone know the CPU and GPU use comparisons of SRT vs. NDI vs Vmixcall approaches?
Scott
What happens if the worker is inside the corporate network (in the office) without VPN? Is there any way for Vmix to work properly considering use of corporate firewalls?
The ports vMixcall uses still needs to be open in the corporate firewall.
vMix Call
