Green screen:is this a good start?
Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Good day again. Well the title says it all. I would like to start experimenting with Chroma screens and such,but I am just wondering if this would be enough proper lighting. Any advice is greatly appreciated. Package: http://www.tubetape.net/...t-Chromakey-Green/DetailThanks, vidkid
Joined: 12/18/2013(UTC) Posts: 3 Location: Atlanta GA
3 box lights is a bit much to light the screen. I would purchase a boom for 1 of the box lights to be above the subjects. This will help with shadowing around the subjects. Also need a couple or a few umbrella lights near the camera to light the subjects.
The box lights remove the shadows from the screen but are not brighter than the subject lighting. Subjects will stand or be at least 4 - 6 feet away from the screen.
Should do the trick. We use this setup all the time with our green screen photo shoots. We are now just getting into video green screen which should not be too much different.
Hope this helps
Thanks for the reply rwhite. Yes,I thought 3 lights was a little much,however,it seems as though the other packages with less lighting were more expensive. So,I went ahead and purchased as a way to get my feet wet.
Thanks again,
vidkid
