SRT
SRT connection issues? - Solved
Thanks: 8 times Was thanked: 3 time(s) in 3 post(s)
Hi all
Is anybody else finding SRT on version 23.0.0.46 really buggy?
Joined: 1/13/2010(UTC) Posts: 5,311  Location: Gold Coast, Australia Was thanked: 4711 time(s) in 1615 post(s)
Can you describe the issues in more detail?
Note that SRT has not been changed or modified since .39, so if you are seeing differences in the latest update, it could be due to increased congestion on the internet in general at the moment, which is outside our control.
Martin vMix
Hi Martin
I'm really excited about SRT and I thought I would setup a test rig to test it out.
I've made a local (same machine) and remote location test setup and they have the same problems
I might have to make a video showing you the problems
I did get it working in both situations (local and remote) but then I changed some settings then I could never get it working again. (I need to do more testing)
I was just trying to get a feel for what others were experiencing...........Its usually an indication of a software problem or local setup problem
I will come back with more details
Here is an example There are also other problems, but we will start here
opps I watched the video and I see a problem
I've just enabled the tick box but it still doesn't show :) Its like the SRT engine needs a restart?
The other thing is the SRT profiles don't seam to be saving?
Also SRT setting profiles are doing something strange. I can't clear them for some reason? Having said that I don't really understand how its supposed to work? Which profile is active? (assuming more than one profile)
after some thought this must be the active profile  but as you can see from the picture above there is only one profile but we can select 2 profiles?
Quote:Important: Rendezvous is for other the internet only, it will not work on the same machine for testing purposes at all. I couldn't find this in the manual :(
Rendezvous is working perfect now, profiles are even loading as expected
The really cool thing is not having to open ports.
I wonder if we can use a "Dynamic DNS" service instead of IP address?
After extensive testing I've concluded that vmix SRT is unstable (23.0.0.46)
The most stable setting I find is "Renedezvous" and ports forwarded correctly on both ends.
If ports are closed it works sometimes, all the other configs are the same "sometimes works"
very frustrating, its just such an excellent concept
These are my settings for best results (with ports forwarded both ends)
Joined: 1/25/2019(UTC) Views messages in topic : 330  Thanks: 23 times Was thanked: 84 time(s) in 64 post(s)
maybe you change your passphrase now, since we can see your duckdns name and passphrase on your last picture...
 1 user thanked Peter1000 for this useful post.
SRT
