Joined: 6/16/2018(UTC) Posts: 30 Location: LOS ANGELES
I would thank anyone with this urgent help. How can I crop virtual set to fit inside the multi-view split box for three people interview? When I try to crop none of the crop tools works. Gust on vmixcall are good but host is in green screen in front of virtual set.
Thanks Fred
Joined: 12/27/2012(UTC) Posts: 5,486  Location: Belgium Thanks: 314 times Was thanked: 1019 time(s) in 837 post(s)
Seems one just can't crop a virtual set ( which is a multiview in itself) , will need to do some sort of masking i think
Thanks doggy, I'm 5 hours away from show, What I did took a snap shot @ 1080 from virtual set with muted talent, then place the snap shot in box 1 . Snap shot of virtual set fits perfectly no need to crop. then used the camera input with chroma in first overlay then crop the frame. I wish there was an easy way.
 Snap 1.png (1,132kb) downloaded 0 time(s).
Quote:I'm 5 hours away from show, preparing and testing earlier is the key :-) glad you found a fix for now
Quote:preparing and testing earlier is the key :-) Yes doggy, took a good sweat out of me.
