Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
Hey a question is it possible that vmix and twitch are not working together at the moment. I have test to log in from vmix to twitch and on all my systems it’s shows up on only a white login window
Joined: 10/1/2016(UTC) Posts: 117  Thanks: 88 times Was thanked: 52 time(s) in 31 post(s)
Originally Posted by: bgbenni  Hey a question is it possible that vmix and twitch are not working together at the moment. I have test to log in from vmix to twitch and on all my systems it’s shows up on only a white login window Same here, after clicking on the Login and Update Channels button it just pops a blank white Web Login screen, I let it sit for a good 15 minutes and nothing? I am running vmix version vMix 4K - 23.0.0.46
Running 22.0.0.069 and 23.0.0.46 both same problem :((
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
I can confirm the Twitch login is working correctly here, may be a temporary outage on the Twitch login site in your area.
You can still use Custom RTMP Server as the destination and copy and paste the Stream Key and URL manually from the Twitch site.
Martin vMix
Originally Posted by: admin  I can confirm the Twitch login is working correctly here, may be a temporary outage on the Twitch login site in your area.
Martin vMix Thanks Martin for the quick response as always! I was already looking into setting up the RTMP into Twitch... If I notice the twitch login site comes back online I will post an update. -s
