Steam @30fps, stage @30 and ingest settings @30
Joined: 3/19/2020(UTC) Posts: 36  Location: Kentucky Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
I am streaming at 30 FPS. my two sources are both sending to vMix at 60fps.
When I add them as inputs should they be set to 30fps even though they send via HDMI at 60FPS to vMix?
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
When adding an input to vMix, its settings should match what the capture device is receiving, usually the same as the camera output. Note however that most major camera brands (Sony, Canon, Panasonic etc) send out 29.97 or 59.94 even if they say 60 or 30, so selecting those instead is ideal.
Martin vMix
Originally Posted by: admin  When adding an input to vMix, its settings should match what the capture device is receiving, usually the same as the camera output. Note however that most major camera brands (Sony, Canon, Panasonic etc) send out 29.97 or 59.94 even if they say 60 or 30, so selecting those instead is ideal.
Martin vMix I sincerely appreciate your time and effort to respond. Will follow the given advice :) Have a great weekend
