Easyworship to vMix to Youtube Live
Hi, I am new to streaming so would appreciate help.
I have managed to use vMix with my laptop camera as the input and successfully stream this via YouTube Live Studio so have got the interconnectivity working using stream keys etc.
However, I can successfully link Easyworship to vMix using NDI input but that output does not appear in YouTube Live studio. I cannot see what I am doing wrong.
Any advice appreciated
Roy, UK
@ Roy
How are you using the EasyWorship Input in your vMix production? Whatever is in your vMix Program Output screen should be sent to Output [1] which is what gets streamed and/or recorded in vMix. Can you verify that Output [1] is set to Output and not something else? Settings===>Outputs/NDI/SRT===>[1] Output===>Output
Hi, thanks for you comment. I got it working, I think it was just a performance issue with my Suface Go. If I put just words of a song on Easyworship the output makes it way through vmix to Youtube Live. However if I switch to the Go camera as a live feed in easyworship the Youtube Live says it is not getting anything.
I am not an expert, have tried to adjust bitrates and resolution settings but no success with vido yet.
The church has just recently bought a hi spec tower PC but no camera on it of course and no digital camera or webcam available so next step is to try and connect an iPhone via wi Ci. Would appreciate any tips on Low budget $100 £100 camera that could connect to Tower PC.
