Hi!
We are now doing a lot of VOD-casts using vMix Call, I guess like many others these days. For editing afterwards we also do a multicorder recording of the calls, but here is the problem: Since the multicorder needs to create a new file each time the resolution of the call changes, we end up with a lot of files for each multicorder, and they also seems to drift a lot out of sync. The solution is to route the inputs though one of the output, but since we have at least 4 callers we do not have enough outputs, one is of course used for PGM mix. Would there be possible to ad more outputs? Or at least some sort of "virtual outputs" to route unstable inputs though so they can be use in both the multicorder and replay?
Kim
Thanks: 16 times Was thanked: 11 time(s) in 9 post(s)
#1 and thanks for the tip about routing via outputs. Was just about to ask the question on whether that would solve the multi corded issue.
