How to receive a stream from remote PC's
Hi! I have two different streams from two observers. These two streams need to receive on PC, combine into one and sent to YouTube. All three PC's (two observers and one receiving) are located in different cities. Is it possible to do this using the vMix and how to configure it?
Joined: 5/13/2014(UTC) Views messages in topic : 521   Location: Manchester, UK Thanks: 2 times Was thanked: 184 time(s) in 131 post(s)
You might want to look at using the SRT protocol, which vMix can both send and receive.
 1 user thanked zenvideo for this useful post.
Originally Posted by: zenvideo  You might want to look at using the SRT protocol, which vMix can both send and receive. Thanks, for advice, I will study this issue.
Originally Posted by: zenvideo  You might want to look at using the SRT protocol, which vMix can both send and receive. Should I buy two licenses if one PC will be configured to output and the second to input with srt?
