Monday Production
#1 Posted : Sunday, March 8, 2020 8:21:43 AM(UTC)
Monday Production
Norway
Hi!
Is the PNY NVIDIA Quadro RTX 5000 fully supported by vmix? And will it be possible to use hardware encoding on everything listed below?
And will it be able to handle 8 SRT inputs, 2 replays (SRT through two of the outputs), 2 recordings and external outputs to SDI (AJA Corvid 88),
1 NDI output, 1 stream to twitch, and 2 SDI cameras input through the AJA Corvid 88, and also 4 NDI Inputs?
And there will of course be some graphic elements and overlays to.
All inputs and vMix project is set to 1080 50P.
We tried this setup with the GeForce RTX 2080Ti BLOWER 11GB GDDR6 PCIe,
but after 1.5 hour we started to get warnings of GPU overload and the sound started to get choppy.
The GPU memory was only at about 47% and the CPU was at about 3-10%
Some more specs. of the computer:
Supermicro 4U/Tower chassis, 8x SAS/SATA, 1200W PSU, super quiet 27dB
Intel Core i9-9940X - 14-Core 3.30GHz 19.25MB 8.0GT/s LGA2066 165W
Supermicro MB C9X299-PGF - 1xIntel Core i3/i5/i7 X-series 8xDDR4 1xGbE 1x5GbE 4xPCIe 2xM.2 2xU.2 OC
Supermicro CPU Cooler - Intel LGA 2011/2066 (opt. G34), low noise 19.5 dB, square/narrow
64GB DDR4 2666MHz Non-ECC Unbuffered Crucial
2 Samsung 860 EVO 1TB SATA3 SSD 2.5" 550/520MB/s R/W (Win OS in raid 0)
2 Samsung NVMe PM981a - 1TB M.2-2280 2400w/3200r MB/s (recording and replay)
Supermicro 2-Port RJ45 Intel 10GbE LAN card PCI-e LP X540
MS OEM Windows 10 Professional 64-bit
AJA Corvid 88
Kim
stevespaw
#2 Posted : Sunday, March 8, 2020 8:54:31 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
It would be best to post all of you system specs.
CPU
Motherboard
Network
Ram
etc......
Steve
