3rd Party Software and Development
UTC Create Toggle Button for Title Animations
Hi I'm trying to figure out how to make a simple toggle button for my title animations to appear. I have an IN animation on page1 and an OUT animation on page2. I can set those up as separate buttons in UTC but I'd like to just have 1 toggle button. Is this possible?
I do not use UTC a lot, I use PanelBuilder, but if you have a button for your you overlay, do NOT select the 'IN or OFF' option, just select Overlay Input 1 (2, 3, 4) depending on which overlay you want....that will trigger it on and off... Then at the 'Bottom Right hand corner of vMix, click on 'Overlay', ..select the overlay number, and for 'Effect', select the animation you want.... I am not sure if this will help you, but it is what I use..
Thanks: 2 times Was thanked: 7 time(s) in 6 post(s)
Yes is possible... my animation is 10 secs banner....(I DECIDED INPUT 4 OVERLAY) on vmix add trigger for automatic out overlay >>> TRIGGER: ON COMPLETION / FUNCTION: OVALERLAY INPUT4OUT (IN MY CASE)/ INPUT: (YOUR INPUT ANIMATION) / DURATION: 500 / DELAY: 0 / VALUE: (NOTING)
ADD FOR AUTOMATIC RESTART >>> TRIGGER: ON OVERLAY OUT / FUNCTION: RESTART / INPUT: (YOUR INPUT ANIMATION) / DURATION: 500 / DELAY: 500 / VALUE: (NOTING)
ON UTC: ADD BUTTON TO SUPERIMPOSE YOU ANIMATION, ADD SCRIPT, 0# COMMAND: OVERLAYINPUTtOGGLE, INPUT: (YOUR ANIMATION INPUT) OVERLAY: (YOU OVERLAY CHANNEL (1,2,3 OR 4)) SAME ON VMIX INPUT TRIGGER,(INPUT TRIGGER SAME ON UTC)
SORRY MY ENGLISH
ESPERO ENTIENDAS LA EXPLICACION
if only is title in and out, ON UTC: ADD BUTTON , ADD SCRIPT, 0# COMMAND: OVERLAYINPUTtOGGLE, INPUT: (YOUR TITLE) OVERLAY: (YOU OVERLAY CHANNEL (1,2,3 OR 4)
