ThomasK
#1 Posted : Friday, March 6, 2020 6:23:40 AM(UTC)
ThomasK
Austria
I searched the forum so far, but wonder if anyone has additional experience.
We want to stream to Azure Media Services, which works fine
For the next live event, we have the requirement to send multiple audio tracks (for different languages), which vMix does not support out of the box?
Any suggestions on how accomplish it with vMix 23 with some workaround?
Thanks,
Thomas
#2 Posted : Friday, March 6, 2020 6:53:23 AM(UTC)
Click the gear icon of the stream quality setting and choose the Video Source AND/OR Audio Channel
ThomasK
#3 Posted : Friday, March 6, 2020 8:18:58 AM(UTC)
ThomasK
Austria
Thanks, but that wont get me multiple tracks, so users can select which track they want to listen to, only one mixed track.
mavik
#4 Posted : Friday, March 6, 2020 7:46:51 PM(UTC)
mavik
Was thanked: 197 time(s) in 177 post(s)
This requires a complete solution from ingest over CDN to player.
#1 you could use the left and right for two languages. Then you have to program the player to understand what you are feeding. The downside. If you listen with headphones you will just hear it on the right or left.
#2 you create two streams. same video but diffrent audio (cog). That doubles your upstream bandwidth. And you need a button on the webpage for each language. Pressing it will load the appropriate stream. Switching languages will load the other stream. This works with all platforms and CDNs
#3 wowza I belief supports ts streams with multiple audio tracks as an ingest format. I have no experiences how this is digested inside the wowza and delivered to the player then. I assume this will only work in the wowza player then.
My way is option #2. It's the most easiest way in my eyes.
ThomasK on 3/7/2020(UTC)
elvis55
#5 Posted : Friday, March 6, 2020 8:25:58 PM(UTC)
elvis55
Switzerland
thanks 1 user thanked elvis55 for this useful post.
mavik
#6 Posted : Friday, March 6, 2020 9:09:12 PM(UTC)
mavik
Yes, I have two channels setup with my streaming provider so I can simultanious stream with two connections. I know, there is a lot of overhead with this solution but that is the solution where you can work with out of the shelf stuff.
ThomasK
#7 Posted : Saturday, March 7, 2020 8:06:59 AM(UTC)
ThomasK
Austria
Thanks, after research I will try to stream to external 1 - 4 with different audio channels and use ffmpeg to mix it and ingest it via rtmp.
ThomasK
#8 Posted : Sunday, March 8, 2020 1:05:29 AM(UTC)
ThomasK
Austria
Okay, no NDI input for ffmpeg anymore after a license clinch / violation of NewTek.
So trying with DirectShow output of vMix.
ThomasK
#9 Posted : Sunday, March 8, 2020 6:05:51 AM(UTC)
ThomasK
Austria
Ok, works fine now into a mp4 file:
ffmpeg -report -y -f dshow -i video="vMix Video":audio="vMix Audio" -f dshow -i audio="vMix Audio - Bus A" -map 0:0 -map 0:1 -map 1:0 -r 25 -pix_fmt yuv420p -vcodec mpeg2video -maxrate:v 8M -minrate:v 8M -b:v 8M -acodec mp2 -b:a 384k "C:\recordedfile-3.mp4"
So replacing the target with
-f flv rtmp://targeturl:1935/live/event
should give us a nice live stream.
Explanation for map in this case (take audio and video from first stream and audio from second stream):
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> mpeg2video (native))
Stream #0:1 -> #0:1 (pcm_s16le (native) -> mp2 (native))
Stream #1:0 -> #0:2 (pcm_s16le (native) -> mp2 (native))
All available input sources from vMix can be listed via:
ffmpeg -list_devices true -f dshow -i dummy
[dshow @ 000001c9664c9380] "vMix Video"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{860BB310-5D01-11D0-BD3B-00A0C911CE86}\{8E14549A-DB61-4309-AFA1-3578E927E938}"
[dshow @ 000001c9664c9380] "vMix Video External 2"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{860BB310-5D01-11D0-BD3B-00A0C911CE86}\{8E14549A-DB61-4309-AFA1-3578E927F974}"
[dshow @ 000001c9664c9380] "vMix Video YV12"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{860BB310-5D01-11D0-BD3B-00A0C911CE86}\{8E14549A-DB61-4309-AFA1-3578E927FF92}"
[dshow @ 000001c9664c9380] "vMix Video External 2 YV12"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{860BB310-5D01-11D0-BD3B-00A0C911CE86}\{8E14549A-DB61-4309-AFA1-3578E927FF94}"
[dshow @ 000001c9664c9380] "vMix Audio"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\{008E145B-DB61-4309-AEA1-3578E927E940}"
[dshow @ 000001c9664c9380] "vMix Audio - Bus A"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\{008E145B-DB61-4309-AEA1-3578E927E944}"
[dshow @ 000001c9664c9380] "vMix Audio - Bus B"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\{008E145B-DB61-4309-AEA1-3578E927E948}"
[dshow @ 000001c9664c9380] "vMix Audio - M A B"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\{008E145B-DB61-4309-AEA1-3578E927E952}"
[dshow @ 000001c9664c9380] "vMix Audio - M A"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\{008E145B-DB61-4309-AEA1-3578E927E956}"
[dshow @ 000001c9664c9380] "vMix Audio - 16Ch"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\{008E145B-DB61-4309-AEA1-3578E927F001}"
[dshow @ 000001c9664c9380] "vMix Audio - Bus C"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\{008E145B-DB61-4309-AEA1-3578E927F002}"
[dshow @ 000001c9664c9380] "vMix Audio - Bus D"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\{008E145B-DB61-4309-AEA1-3578E927F003}"
[dshow @ 000001c9664c9380] "vMix Audio - Bus E"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\{008E145B-DB61-4309-AEA1-3578E927F004}"
[dshow @ 000001c9664c9380] "vMix Audio - Bus F"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\{008E145B-DB61-4309-AEA1-3578E927F005}"
[dshow @ 000001c9664c9380] "vMix Audio - Bus G"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\{008E145B-DB61-4309-AEA1-3578E927F006}"
[dshow @ 000001c9664c9380] "vMix Audio - M A B C 8Ch"
[dshow @ 000001c9664c9380] Alternative name "@device_sw_{33D9A762-90C8-11D0-BD43-00A0C911CE86}\{008E145B-DB61-4309-AEA1-3578E927F101}"
thanks 1 user thanked ThomasK for this useful post.
ProSonas on 3/8/2020(UTC)
elvis55
#10 Posted : Sunday, March 8, 2020 8:46:22 PM(UTC)
elvis55
Switzerland
Setup multi-camera events ???
youtube multi-camera events
Here's an example
Click on the double arrow icon (←→) at the bottom right next to the gear.
