Hello guys, I was wondering if it was possible in vMix to have the ACTIVE input duplicated? So if I select the same input in the preview I can edit it without modifying what is currently live. OBS has this option and it is super handy. Duplicate active inputThanks for your help
you can make a virtual input ( copy of it or any )
Thanks for the reply but that doesn't answer my initial request :) I can't duplicate all input when I do a transition. I need vMix to do it silently for me (like OBS Studio does)
Originally Posted by: Co6Studio  Thanks for the reply but that doesn't answer my initial request :) I can't duplicate all input when I do a transition. I need vMix to do it silently for me (like OBS Studio does) Yes. It does. You can duplicate any input, including one with multiple layers. Right-click over the cog and select "Create Virtual Input."
Sure but that's not very handy at all, especially during live stream ;)
My question is what do you want to actually edit ? surely not a live camera
