Feature Requests
IRP: skip e.g. 10 seconds back / forward
Thanks: 186 times Was thanked: 20 time(s) in 17 post(s)
Sometimes I tag IRP events after the live broadcast. I let the IRP run and then enter events. There are phases in the recording, where I know for sure, nothing relevant happens (e.g., time-outs of a basketball game). I'd like to be able to skip ahead for e.g. 10 seconds in the running playback of the entire IRP capture. It would be great if there were 2 extra buttons, skip back & skip ahead, for which the amount of time to skip, would be configurable in the settings. If there were no room for these buttons in the GUI, at least the functions should be there, and should then be assignable to keyboard shortcuts.
did you try the shortcut ReplayJumpFrames ?
 1 user thanked xaver for this useful post.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Ario  at least the functions should be there, and should then be assignable to keyboard shortcuts. There is and they are. fwd.JPG (44kb) downloaded 0 time(s).
 2 users thanked doggy for this useful post.
or as Xaver suggests but will have to add the Replayplay to the same shortcut as it stops otherwise
thanks for the tips, I will certainly try those !
Feature Requests
