sytem
#1 Posted : Thursday, February 27, 2020 3:23:03 AM(UTC)
sytem
Finland
I was doing screen capture from different problem, recoderd screen with Newtek Scan Converter and Studio monitor (to keep vmix free to boot and mix things needed to prove issue)
I recorderd one session with no issue, then decided to update vmix to latest (from 23.0.0.38) to make sure that there is nothing fixed already on that version. After Vmix upgrade, the record button of studio monitor is lost. Did the vmix update do something wrong with system-wide NDI-library?
Any ideas what its wrong?
#2 Posted : Thursday, February 27, 2020 3:29:10 AM(UTC)
just tested , no issue with , no record button lost .39
is your mouse hovering over the monitor ?
sytem
#3 Posted : Thursday, February 27, 2020 3:46:19 AM(UTC)
sytem
Finland
Found my (stupid) error, had shortcut on desktop, pointing to old portable NDI monitor (v. 3.8) and at start menu was shortcut newer 4.0 version. So at first I started it from menu, and second time from desktop...
#4 Posted : Thursday, February 27, 2020 4:08:50 AM(UTC)
Aha , those shortcuts. they do tend to move around a bit ;-)
