xemles
#1 Posted : Wednesday, February 26, 2020 1:45:41 AM(UTC)
xemles
France, Metropolitan
I'm having a problem with the DataChange animation.
Basically, the animation just cuts off when there's multiple Text boxes that changes their data, it starts playing the animation then cuts off.
It works well just when one data changes at a time.
I tried only with "DataChangeIn.Text" and stuff like this, not with "DataChangeIn" because datas don't always change and I don't want everything to disappear when there's one thing changing
stigaard
#2 Posted : Wednesday, February 26, 2020 5:54:16 AM(UTC)
stigaard
Denmark
Are you changing the data manually via the Title Editor popup? Switch off 'Live' mode, and then do the changes, then switch on live mode again.
If you are using the API to enter the changes, you can use PauseRender and ResumeRender functions to wait for multiple changes for the title before it is being rendered (and the DataChange is picked up).
xemles
#3 Posted : Wednesday, February 26, 2020 6:16:46 AM(UTC)
xemles
We're changing it through data sources
shawntempesta
#4 Posted : Wednesday, March 4, 2020 3:39:23 AM(UTC)
shawntempesta
Was thanked: 9 time(s) in 7 post(s)
Bump. Have same issue. Got the main lower third, but an additional "tab" that shows the category of the story (it might go from "News" to "The Feed"). The size of the bounding box doesn't change until the very end of the animation, so the box keeps the size of the prior title, while showing the new title, until all animations are complete, then it cuts to the correct size.
Gunnar
#5 Posted : Saturday, April 4, 2020 9:32:11 PM(UTC)
Gunnar
Sweden
I have had the same problem with one Titel with 8 different aninated cubes with pictures changing from datasources outo next
They interfear with another with cut and I didn´t found a solution to that.
#6 Posted : Saturday, April 4, 2020 9:37:32 PM(UTC)
Was thanked: 4674 time(s) in 1609 post(s)
There appear to be different issues being reported here, so please email us and send us a copy of the title template and steps to replicate so we can investigate further.
I can confirm that bounding box sizes will not update in the middle of an animation, as that would change the trajectory of the animation in many cases
and we can't dynamically recalculate animations every frame on the fly without running into numerous unintended side effects, so plan accordingly.
