DDB
#1 Posted : Wednesday, February 19, 2020 5:23:06 PM(UTC)
DDB
I wasn't sure how to describe this so...
I teach a lot and would like to use a touchscreen enabled laptop or Samsung tablet to draw on to demonstrate points or write things down for the viewers to see to complement me going through slides and me direct to camera using my main PC with Vmix on it.
My main PC is not a touchscreen so I'm looking for a way to do that with my existing hardware-the laptop or tablet
I'm assuming NDI will be involved...Vmix call?.
What's the easiest and most efficient way to do this?
TIA.
Daryl
dmwkr
#2 Posted : Wednesday, February 19, 2020 7:51:00 PM(UTC)
dmwkr
DDB
#3 Posted : Wednesday, February 19, 2020 11:53:41 PM(UTC)
DDB
Thank you, I've seen this. The problem is that I don't the means to use a 'pen' on my PC. Yes I could use my mouse technically but not easy or practical.
I have a standard PC setup. Dell with two monitors, mouse.
I have touch-enabled devices that I CAN use to draw on a screen though.
dmwkr
#4 Posted : Wednesday, February 19, 2020 11:59:16 PM(UTC)
dmwkr
Ok, maybe I misunderstood and I haven't tested it, but I thought you would use it on your touchscreen enabled laptop. Panamation has a NDI Input (from your main vMix PC) and NDI Output (to your main vMix PC).
DDB
#5 Posted : Thursday, February 20, 2020 12:03:24 AM(UTC)
DDB
Ooooh, k. I misunderstood. I'll check it out later today. Thanks!
yunxia
#6 Posted : Tuesday, March 2, 2021 4:05:37 PM(UTC)
yunxia
I prefer handwritten notes to typing, so I connected my XP-Pen Digital Tablet to my laptop to use with whiteboard app.
