Can't seem to work out the syntax. Help!
Joined: 7/5/2019(UTC) Posts: 28  Location: Sydney Was thanked: 5 time(s) in 4 post(s)
Trying to send commands from companion to vmx I need to move up or down lines in a spreadsheet via data sources.
I have tried the following commands with no luck.
DataSourceNextRow xls,Sheet1 DataSourceNextRow, xls,Sheet1, DataSourceNextRow xls, Sheet1,
Any ideas
It needs a bit more specifics in the commands.
Check out the helpfiles but also the post about scripting for dummies. Prob best to use the http commands
