ralston
#1 Posted : Wednesday, February 19, 2020 5:21:48 AM(UTC)
ralston
I have a client who wants me to zoom into his company web page and at the same time feed it out of vMix via NDI. I can import the page correctly but can't see a way to zoom into the page once I am in vMix. Any ideas ?
mjgraves
#2 Posted : Wednesday, February 19, 2020 5:38:03 AM(UTC)
mjgraves
Easy.
- Use browser input to collect the web page (Input #1)
- Create a copy (virtual input) and zoom that in (Input #2.) Zoom is done in the input settings using the reposition tools.
- In External Settings - send Input #2 to Output #2
- On program output run merge transition between Input #1 and Input #2
Program out will see the zoom in, or whatever you have on program.
Output #2 will only see the web page full, until you change what's assigned to output #2.
Incidentally, when live streaming and feeding projectors at a conference I usually use Output #2 & #3 for the projectors, and a Streamdeck with buttons programed to change outputs 2 & 3.
ralston
#3 Posted : Wednesday, February 19, 2020 9:02:24 AM(UTC)
ralston
Hi thanks for your suggestion. Let me explain in better detail, I have a web page that I need to zoom into using chrome Ctrl+ in order to get better detail with the text needing to be enlarged. I understand I can zoom in using position etc but that doesn't help with the actual resolution of the fount. My question is this .. Is it possible to use Ctrl + command whilst you have captured the browser in vMix.
dmwkr
#4 Posted : Thursday, February 20, 2020 10:16:06 AM(UTC)
dmwkr
Workaround: Use a second display or computer and capture via NDI?
mavik
#5 Posted : Thursday, February 20, 2020 7:43:07 PM(UTC)
mavik
Way too complicated. May I suggest just to use desktop capture. Open the page in a new chrome tab. Grab the tab and move it outside so that a new window appears. In desktop capture you now see two Chrome instances. Bring the one with the webside in and do whatever you need to do with that webpage. It will be reflected in the input.
Then apply Michaels suggestion.
