dasmedienatelier
#1 Posted : Tuesday, February 18, 2020 4:35:40 AM(UTC)
dasmedienatelier
I am using nodejs to write data into a text file which I want to use as a datasource. When trying to add the text file via the datasource manager I always get the error:
"Error: process cannot access the file since it is in use by another process" (translated from German)
As soon as the nodejs app stops vmix will access the file and refresh the data.
Other programs (i.e. Atom, Texteditors) can access the file while it is being written. What am I doing wrong??
Any insights much appreciated!!
Thanks,
Knut
xaver
#2 Posted : Tuesday, February 18, 2020 4:58:04 AM(UTC)
xaver
nodejs should open the file, write into the file and close/unlock the file
dasmedienatelier
#3 Posted : Tuesday, February 18, 2020 5:27:53 AM(UTC)
dasmedienatelier
But why can other applications load the file while it's in use by nodejs and vMix can not? I am simply using fs.writeFile().
xaver
#4 Posted : Tuesday, February 18, 2020 6:50:45 AM(UTC)
xaver
you are sure, you can write with other editors at the same time?
if you open a file with excel, other programs can't write to the same file at the same time,
but most editors can open it, but not save the changes you made in the editor
dasmedienatelier
#5 Posted : Tuesday, February 18, 2020 5:07:39 PM(UTC)
dasmedienatelier
ah, so vmix needs write access? Isnt it possible, to have it only reading the source? Like an option: „Datasource open read-only“
xaver
#6 Posted : Tuesday, February 18, 2020 6:01:36 PM(UTC)
xaver
I'm not sure
never tested it
we have to ask Martin
dasmedienatelier
#7 Posted : Tuesday, February 18, 2020 8:41:34 PM(UTC)
dasmedienatelier
Well, Martin? :)
#8 Posted : Tuesday, February 18, 2020 9:59:16 PM(UTC)
Originally Posted by: dasmedienatelier Go to Quoted Post
Well, Martin? :)
Yes, Martin is checking this forum 24/7 (so timezone doesn't matter)
why not message support ?
#9 Posted : Tuesday, February 18, 2020 11:43:12 PM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
I am everywhere!
Reading a file while it is in use by another program is a very bad idea!
Consider if the program only half finished writing to the file when vMix updated, you would end up with scrambled
or incomplete text in your titles!
Instead, all file data sources should save to file when updates are made and not keep the file open.
(Excel and Notepad do this for example).
Thus when vMix reads the file successfully it can always be sure the data is complete.
dasmedienatelier
#10 Posted : Wednesday, February 19, 2020 12:12:47 AM(UTC)
dasmedienatelier
Thanks for replying, I really appreciate that.
I am using google's speech API for transcribing and generating subtitles. Currently, I am writing the returned transcription into a textfile which I tried to use as a datasource. Since the results are coming in pretty fast I need to rewrite the file very often. Maybe too often, so it seems, that the file is always locked.
I guess I have to find a different way of sending subtitles to vMix, then. Since I don't know if there is a way of sending subtitles as metadata along with a livestream?
Thanks,
Knut
dasmedienatelier
#11 Posted : Wednesday, February 19, 2020 5:00:17 AM(UTC)
dasmedienatelier
Found a solution: I'm now using vMix's web API. I'm simply sending the subtitles via http/tcp instead of writing to a file.
Furthermore, I have found a nodejs vmix module which makes it pretty easy to send commands to the vmix webinterface.
Thanks again to all,
Knut
