lbandrade
#1 Posted : Wednesday, February 12, 2020 9:36:13 PM(UTC)
lbandrade
Brazil
I`m trying to use a RS232 input as a data surce JSON.
I`m encoding the serial string as this to be in json style: {"name":"***"}
Passing this string to a Serial-TCP who create a localhost with that string.
But on Vmix when I select Json and use the url http:/10.20.36.10:1001 I got the following error: The server committed a protocol violation.
Is there any thing that I could do to fix this issue?Vmix is blocked to accept unsecure url?
Thank you all.
MartLeib
#2 Posted : Wednesday, February 12, 2020 9:55:17 PM(UTC)
MartLeib
Estonia
First of all, your JSON will not work with vMix. You need object inside array. Like so:
Code:
        "name":"***"
If you want to have more than 1 entry, you just add objects:
Code:
        "name":"***"
        "name":"###"
Could you share output of the http:/10.20.36.10:1001 when you open it in the browser? Does Chrome open it nicely, if it does without errors, this should not be HTTPS/HTTP case.
Probably related to your software not providing correct headers.
lbandrade
#3 Posted : Wednesday, February 12, 2020 10:04:50 PM(UTC)
lbandrade
Brazil
Hi, thank you for your response
I change the string to :
[{ "name":"***" }]
like you told.
Sorry I type the wrong IP the correct is http://10.20.36.125:1001/
I`m trying to connect on the browser but with no success:
ERR_INVALID_HTTP_RESPONSE
No connction.PNG (14kb) downloaded 0 time(s).
I`m testing with the CommFront Serial-TCP program to generate the server.
MartLeib
#4 Posted : Wednesday, February 12, 2020 10:42:16 PM(UTC)
MartLeib
Estonia
I believe that this software does not work as you need it to work. It probably creates TCP server which vMix can not use. vMix needs HTTP server for data source.
I have used Node.JS for serial reading and express for outputting that data on the HTTP server. You may contact me at mart.leib.estonia@gmail.com
