alifw
#1 Posted : Wednesday, August 3, 2011 5:14:56 PM(UTC)
alifw
I've been having a problem with an audio delay. The Black Magic graphic card input and Black Magic output are connected to the slingbox to the internet. There has been about a 3 second delay on the audio. I tried setting a delay to the external audio box for 1,000 ms without any changes. Does anyone have any advice on how to fix this?
Thanks!
#2 Posted : Saturday, August 6, 2011 9:18:49 AM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
See if the following steps help:
1. The Audio source should be added alongside the Video capture source from Add New Input under the Capture tab.
This feature is available using the latest vMix 2011 v10 from our web site.
2. When setting up the external output, select "Stereo Mix" or "What u hear" as the Audio Input Device.
If this option is not available, see the following for setup instructions:
http://forums.vmix.com.a...t.aspx?g=posts&t=170
3. Tick the Audio button for the capture input so it is green and click Start for the external output. The external output should now include sound that is in sync.
alifw
#3 Posted : Sunday, August 7, 2011 4:22:24 PM(UTC)
alifw
Hi Martin
I still have problem with audio delay (v10)…
I am using black magic card #1 for input and black magic card #2 for output
Thanks, Alif
